Networks NTL Digibox
Discussion in 'Hardware' started by Slink, 15 Mar 2002.
  1. Slink
    Slink B7
    7 Oct 2001
    Anyone got NTL digi?
    It has a modem built in right?
    Is it posible for users with non cable modems to run there pc thru it?,
    Just a qeury
  2. Slink
    Slink B7
    7 Oct 2001
    Bump0x
  3. Phil
    Phil What's a Dremel?
    19 Jul 2001
    no it's not possible.
  4. Martin
    Martin What's a Dremel?
    4 Mar 2002
    your need a network card in your P.C. mate and a x over cable to connect to the ntl box.
  5. Phil
    19 Jul 2001
    have you actually done this ?
    he's talking about the television cable box not the cable modem...
    as far as i knew they have an RJ-11 for connecting to the phone line but nothing else....
  6. Martin
    4 Mar 2002
    S.T.B. (SET TOP BOX)
    On the back of the S.T.B. there is a RJ45 Connector. You need to connect this to your Network card via a x-over cable.
  7. CrOaKeR
    CrOaKeR Host warrior 4, Vengence!
    21 Feb 2002
    There are loads of connectors on the back of those boxes, including parallel an serial sockets. I don;t think you will be able to utilise any of it without the correct software being installed on the box tho. All it seems to be is an ickle computer, should open mine up one day! :eyebrow:
  8. Martin
    4 Mar 2002
    It does work !
    The guy who sits next to me in our office has done it he had a port called x-over and sure enough that , means it needs a cross over cable. See below if you guys are having problems this is a good site for reference.
    Help
  9. CrOaKeR
    21 Feb 2002
    ok ok
    Looks convincing, lets get testing! :lol:
  10. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    In theory, then, does that make multilinking cable modem & STB possible?
  11. Phil
    19 Jul 2001
    i stand corrected...
  12. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    does this really work then??
