Small Form Factor NUC or Brix for VMs?
Discussion in 'Hardware' started by meandmymouth, 28 Nov 2018.
  1. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Has anyone used a NUC or Brix or similar tiny, low-powered PC with ESXi or something else for virtualization?
    I can pick up a J1900 based Brix for about £90 and already have dimms and an HDD for it so just wondering if it's worth it.
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    Do the CPUs in these support VT-x?
  3. Xlog
    Xlog Minimodder
    16 Dec 2006
    What CPU in nuc?
    Most limiting factor will be RAM, j1900 supports max 8gb. Depending on what you are doing on your vm's, that might not be enough for just one.
  4. meandmymouth
    15 Sep 2009
    The ones I've looked at all support VT-x and 8GB is fine as I'll only be running linux VM's for testing and training. 1 or 2 vCPU cores and 2GB should be fine.
    Before anyone suggests R-Pi's - I have a couple already.
  5. Yaka
    Yaka Multimodder
    26 Jun 2005
    hope this is ok with the mods,
    if your after a nuc i have one that didnt shift in the marketplace here, nuc 5i5ryk yours if you want it
  6. meandmymouth
    15 Sep 2009
    Can you point me in the direction of that post in the marketplace? I've had a look but can't find it.
  7. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    They are great, i know a bunch of people who use several and they work really nicely
  8. meandmymouth
    15 Sep 2009
    For general use or VM's?
  9. crazyg1zm0
    20 Feb 2007
    Both, theres plenty running them as ESXi hypervisors and then running plex, radarr, sonarr, sab, web servers and much more,
  10. crazyg1zm0
    20 Feb 2007
    I want to grab a nuc or 2 for myself to play around with ESXI control server, as i use an ESXI machine at the moment but its just one so i dont have a central control server
