Graphics NVidia Control Panel Missing
Discussion in 'Tech Support' started by Pookeyhead, 29 Feb 2020.
  1. Pookeyhead
    30 Jan 2004
    Just updated drivers, and I've lost NVidia control panel. This has happened before, and it suggested I download it from the MS Store... a pain, but only took a second, so (shrug)... However, this time, I can't download it, and when I check "system requirements" I get this...
    The drivers are on and working... this is just control panel.
    I've looked for solutions, and most say you un-hide it in control panel... but there's nothing in control panel. The associated folder in C:/program files/Nvidia Cporporation are not present either. I just don't have it, and cannot download it. Any hints from anyone who's been here?
    Thanks
  2. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    I've had this problem before, you've accidentally downloaded and installed the studio driver, you want the game ready one. it used to be hard to tell them apart but they've since started labeling them more clearly.
  3. Pookeyhead
    30 Jan 2004
    I'm pretty sure I've not... I'll DDU the driver and start again to be sure though. Thanks.
  4. Pookeyhead
    30 Jan 2004
    DDU'd the driver while in safe mode... downloaded it again (definitely the GRD driver) and same problem persists.
  5. Pookeyhead
    30 Jan 2004
    Just thought I'd see if installing the studio drivers fixed it, but there's no studio driver available for a GTX900 series card... Grrrr... this is driving me mad.
  6. Pookeyhead
    30 Jan 2004
    Sit Rep: Just thought I'd let Windows install a driver... but nope! 524564563.JPG
    I'm beginning to find AMD cards attractive round about now LOL
  7. Gunsmith
    23 Sep 2005
  8. Pookeyhead
    30 Jan 2004
    I just DDU's the drivers again, and downloaded the ones from your link, and it's exactly the same.. seems to be the same driver.
  9. Gunsmith
    23 Sep 2005
    then try an older one, see if it install there.
    are you doing a complete DDU inc binning of the nvidia folder as well?
  10. Pookeyhead
    30 Jan 2004
    Yep... hosing everything out. It's a bit crap when you have to roll back to an older driver. I'll try that though.. thanks.
  11. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Pookey...just incase you haven't, and its often overlooked, this is my procedure for DDU.
    Download latest Nvidia drivers
    Download DDU
    Disconnect from internet to save Windows pulling down it's own drivers
    Run DDU, let it restart the PC
    Install latest Nvidia drivers
    Reconnect to internet
    I've found if you dont disconnect from the internet Windows can and often does pull whatever driver it feels like from the net and that's when you run into problems installing the latest Nvidia drivers.
    Fingers crossed it works for you ^
  12. Pookeyhead
    30 Jan 2004
    I tried that. It installed drivers, but there was no option to install Geforce experience while offline, and also... it still didn't work. The driver always installs perfectly.. no issues... it's just the lack of nvidia control panel that's the problem. Thanks for the suggestion though.. appreciate it.
  13. Gunsmith
    23 Sep 2005
    i think i know whats going on, i think windows is installing the DCH oem driver upon first start up kinda like how vista would store and install a local driver from its driver store, DDU it again but look for the option to disable windows pulling down and installing drivers, then install afresh
  14. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    I've had that but usually what happens in that scenario is that you get an error message when trying to install the drivers from NVidia. Pookey has the NVidia drivers installed, he just can't find the NVidia control panel.
    Edit: TechPowerUp did an article about it but I'm still not convinced this is Pookey's problem.
  15. Pookeyhead
    30 Jan 2004
    OK.. sorted. I had to track down a non DCH driver, which there is... just hard to find. It's the latest one.. just non DCH. I got it from 3DGuru's website. file name "442.50-desktop-win10-64bit-international-whql.exe". NVidia control panel now working, with no stupid need to go to MS Store. I hope I don't have this hassle with every driver update from now on!
    Thanks everyone.
  16. Fingers66
    30 Apr 2010
    Aha, so the DCH driver was your problem.
    I have got into the habit now of installing Win 10 without a GPU installed and letting it get everything installed and sorted, then downloading the driver from NVidia, unplugging the internet, fitting the GPU then installing the NVidia driver. The DCH problem was a ballache when I first got it so I just do it this way now.
    That said, once you have a *real* NVidia driver installed, future downloads and installations from NVidia should work as intended.
  17. Pookeyhead
    30 Jan 2004
    Looks like it, yes.
    No integrated graphics, so not an option for me I'm afraid.
    Lets' hope so!
    Thanks again all.
  18. MADPC
    MADPC Minimodder
    10 May 2020
    I know the nvidia panel is outdated isn't it?
  19. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    there updating it for RTX 3xxx to be more modern
  20. DanH
    DanH What's a Dremel?
    19 Jul 2019
    Stop and start the nvcpl process in taskmanager this worked for me
