Hardware Nvidia G-Sync monitor up for pre-order
Discussion in 'Article Discussion' started by Meanmotion, 16 Dec 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    That sounds like its going to be popular :eeek:
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Well it shouldn't become more expensive at least... right? Might be a nice feature for upcoming 4k panels actually, considering I would expect consistently dipping framerates on demanding games, even with top-notch systems. And at that level, the extra £160 or something would be very palatable for a genuinely better experience.
  4. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Eh, it's still very early days. Apparently most of that cost is because Nvidia have used an FPGA for the first G-Sync board to get it out onto the market. The price will drop drastically once they fab an ASIC for it.
    I think G-Sync should be ideally suited for 4K monitors - not only does their high price make them suitable for swallowing the cost, the fact that you only need to pack enough hardware to reach 30-40fps rather than 60fps for a smooth image means 4K gaming will becoming a far more realistic proposition.
  5. DC74
    DC74 Doh!
    4 Jan 2011
    Guess only those with deep pockets will be buying them then, well until the manufacturers get sick of all that stock not selling and decide to drop prices a bit. I would say they should cost no more than £50-75 more than the standard monitor in order to take off.
    This price is a bit scary to say the least, if they want it to catch on and become widespread they need to start surveying people and I don't mean the usual Nvidia fan boys and asking them what they think is a fair price. God I wished there was a 3rd competitor in the GPU industry instead of the current one horse and a lame donkey race we have at present.
  6. Panos
    Panos Minimodder
    18 Oct 2006
  7. wolfticket
    19 Apr 2008
    So Nvidia have created a device that reduces the requirement for powerful graphics hardware... Did they think this through? :)
  8. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    G-sync's benefits are actually in the lower refresh rates, where performance can vary wildly between 30fps (where G-sync begins frame-doubling) and 60fps. While normally this delay variance would exhibit as stutter and/or tearing (depending on buffering setup used), G-sync will just push complete frames as and when they're rendered.
  9. theshadow2001
    3 May 2012
    G-Sync on a massive 4k IPS screen
  10. ZERO <ibis>
    ZERO <ibis> Minimodder
    22 Feb 2005
    Still making their way closer to a CRT, if only we could still buy CRTs we would not have all these problems...
  11. jb0
    jb0 Minimodder
    8 Apr 2012
    While I do still love CRT, CRTs also operated on a fixed refresh rate at any given time.
    While they DID have multisync monitors, you couldn't adjust the refresh on a per-frame basis because the beam waits for no man. If you miss VSync, you can't just say "hold that frame for a few beats, I'm not ready yet." You have to put SOMETHING up.
    In this case, they're actually removing a restriction that only exists BECAUSE of CRTs, not working around a restriction that didn't exist on CRTs.
  12. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    unless it is open for others (cough AMD), I don;t think i'd care for a monitor that supports g-sync
Tags: Add Tags
