Graphics Nvidia GT 610, 620 and 630 on scan
Discussion in 'Hardware' started by Amsalpedalb, 15 May 2012.
  1. Amsalpedalb
    Amsalpedalb What's a Dremel?
    24 Nov 2010
  2. KidMod-Southpaw
    28 Sep 2010
    Zotac have made a 4GB GT630.
    WHY!?
  3. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    I'll be interested in seeing whether these are actually reworked or just rebadged 520's. I sell a lot of basic video cards to my clients.
    4GB of RAM on a 630 but they cant f#$!&#! deliver a solid 4GB 670 with aftermarket cooling and 680 PCB that is so sought after... urgh... frustrating.
    After looking them over, 96 cores on the 620/630... not too bad for a budget card actually.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    680 & 670's don't need 4GB...
  5. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    Funny you should say that... at 5160x1200+1920x1080 I've gotten mixed reviews on whether 4GB will be necessary with 670 SLI. With quite a few of the charts I've seen showing today's games holding steady at the 2GB mark, I just can't bring myself to grab a card without room for expansion. I tend to keep my cards for ~4 years so I am looking for a set of cards for the long term.
  6. Cei
    Cei pew pew pew
    22 Mar 2008
    Probably just rebadged 5xx series cards unfortunately.
  7. faugusztin
    11 Aug 2008
    The reason is simple - 4GB cheap GDDR3 or DDR3 vs 4GB of expensive GDDR5.
  8. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    That 610 card is literally just the GT210 (Google image it.), 620 looks like much the same...
    630 might just be a new GPU, might not be as godawful as the 10 & 20.
  9. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    Yea, but 4GB of cheap GDDR3 on a card that will never, ever, use it, or 4GB on a card that people are likely to run NVIDIA Surround on with massive resolutions.
    The 610 is almost definitely a rebadged 520, but both the 610 and 520 have 48 cores compared to the 210's 16. The 620 and 630 look to be a new 96 core GPU... not too bad for a basic graphics card. Actually, I just looked up the 430, it had 96 cores as well... probably got a new 6xx series badge then.
  10. faugusztin
    11 Aug 2008
    You know that, i know that, we know that - but the typical buyer don't know that. He sees 4GB on graphics card, that must be supercool.
  11. Amsalpedalb
    24 Nov 2010
    I really hope these are not just rebadged cards. Though they do seem to be claiming that they're 28nm, so maybe at least they've had a die shrink.
  12. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    There is a version of the GT630 that has 196 cores and I believe it is Kepler-based. However, it is OEM only at the moment as far as I am aware.
    EDIT: I must correct myself. The kepler-based GT 630 (OEM) has 384 cores
  13. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    Huh? That listing is utterly confusing. 3 vastly different GT 640s?...
    Wow... I just looked it up and that list looks correct... wtf NVIDIA? I understand that rebadging moves products, but it looks like they just said "we're too lazy to have lots of part numbers, we'll just call all the cards the same thing".
    So I can buy a GT 630 with 96 cores at 810MHz, or I could buy at GT 630 with 192 cores at 875MHz.... those are equivalent right?
  14. aka_jesse
    aka_jesse What's a Dremel?
    14 Apr 2011
    Looks as though this has been done just to confuse people buying ready built machines. I don't know how they can explain a 630 being faster than a 640 from the off!
  15. faugusztin
    11 Aug 2008
    Probably going to be GT640 Ti, GT640, GT640SE. How is that different to GTX 560Ti, GTX 560, GeForce GTX 560 Ti 448 core and GTX 560 SE ? :D
