News NVIDIA releases new 680i BIOS - fixes problems?
Discussion in 'Article Discussion' started by Tim S, 19 Dec 2006.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    i must be one of the lucky ones, ive not had a single problem since installing it, could it be that im running my drives at 3GBs? :confused:
  3. Tim S
    Tim S OG
    8 Nov 2001
    It doesn't affect every board, which is why it's a tricky problem to track down (and fix) - I'm glad you've been luckier than we have, I'd be about ready to throw the board back at NVIDIA/EVGA if I was a paying customer and had gone through three boards. :)
  4. samkiller42
    25 Apr 2006
    Hum, i also think im lucky with my board, just unlucky with the ram im using, would you recomend me upgrading the bios with this tim?
    Thanks for using a small slice of my thread as well :D
    Thanks
    Sam
    Edit: Tim, this is the ram im using (2*1gb)http://www.corsairmemory.com/corsair/products/specs/CM2X1024-6400.pdf, can you tell me if it is good or not, im also thinking of replacing the EVGA with a striker, would this ram be ok in the striker, cheers Tim
  5. phat-ant
    phat-ant What's a Dremel?
    23 Feb 2006
    no problems on my board so far touch wood.
    but will probably update the bios just for fun :)
Tags: Add Tags
