Graphics Nvidia Surround and Tri SLi
Discussion in 'Tech Support' started by ZortB, 23 Sep 2011.
  1. ZortB
    ZortB What's a Dremel?
    23 Apr 2009
    After a while of running 3 Monitors in extended desktop I decided to set up Nvidia Surround for my tri sli gtx 580s. Going into Nvidia control panel get the following screen showing only 2 cards possible for sli.
    So I went into the configure screen which again shows only 2 cards available or sli but states the attached screens wont be used.
    This shows setting up the screens to 2 cards but i assume that if i do so then sli will be running off of 2 not 3 cards. I have the screens set up 1 per gfx card as required last time i set up surround.
    I'm probably missing something obvious but does anyone know how to solve this. Was using 280.XX drivers and have even reverted to 275.33 to try to solve this but no joy.
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Maybe try turning Auto Select off for which one is doing Physx?
  3. ZortB
    23 Apr 2009
    Have tried physx on auto, specific gpu and cpu. No diference.
  4. noizdaemon666
    15 Jun 2010
    I know this is a really stupid question, but the SLI bridge is in place isn't it? And what motherboard are you using?
  5. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    probably the driver.. nvidias surround is a software solution unlike ati eyefinity which is done in hardware
  6. ZortB
    23 Apr 2009
    The Mobo is an asus p56x58d-e. had tri sli running on this before. sli bridge is in place. another stupid question in return. Is there a correct orientation for the sli bridge? currently got it so the writing is ' the right way up'. Thanks.
  7. bulldogjeff
    2 Mar 2010
    Go back to maximise 3d performance and see if you get the tri sli running that way. If nothing else it'll prove that everything is as it should be. And the bridge can only go one way.
    noizdaemon666 likes this.
  8. ZortB
    23 Apr 2009
    Thanks for the help. Swapped the bridge and its working again.
    Ahhh back to 3 screen loveliness :D.
  9. noizdaemon666
    15 Jun 2010
    +rep for finding an easy solution :D Do you mean swapped for a different one or swapped its orientation?
  10. ZortB
    23 Apr 2009
    Swapped the bridge for another 1. tried swapping the orientation but it doesnt fit properly. Probably to stop people trying it.
    Thanks for the rep but Bulldog jeff deserves it as he suggested it.
  11. noizdaemon666
    15 Jun 2010
    Rep for Jeff too :D
