News NZXT announces Grid fan hub
Discussion in 'Article Discussion' started by Gareth Halfacree, 17 Apr 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    They should create a version for 4-pin PWM fans, and then with a single PWM header from the hub to the motherboard.
  3. misterd
    misterd dremel eater
    16 Sep 2007
    Is there a reason devices such as this aren't using SATA power connectors? They're on every power supply now, and nothing else in my system uses molex anymore. On any of the modular power supplies I've used the molex ends are on a separate cable from the SATA ones. I like to keep things tidy. </rant>
  4. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Thats what I thought as well at first but surely if you want PWM control then you would rather control fans individually or in sets and there are already fan controllers that offer that such as the in depth mCubed T-Balancer,
    I don't really see the point of this though either as who wants up to 10 fans all running at full blast all the time? Especially as those with enough space to fit that many fans will have a case that either has an included fan controller or at least would be of a high enough value to mean that the buyer would not mind spending just a little more for a proper fan controller.
  5. ziza
    ziza What's a Dremel?
    21 Dec 2010
    Agreed a SATA hub would be more useful, but many FAN do not come with such connectors.
