O hai, FSP!
Discussion in 'FSP' started by Mattmc91, 1 Mar 2011.
  1. DaTLiTe
    DaTLiTe What's a Dremel?
    26 Apr 2009
    Greetings FSP.....Hands up who owns an FSP PSU?
  2. adidan
    25 Mar 2009
    Gilljoy is the only one so far in the thread.
    Hopefully their partnering with this site means they're heading into our sort of market with some enthusiasm.
  3. Xlog
    Xlog Minimodder
    16 Dec 2006
    Have 3 (bluestorm and 2x 180W 1U), they all still work, so no complaints.
  4. Guest-23315
    Guest-23315 Guest
    I had a Bluestorm 600W back in the day.
    Welcome :thumb:
  5. Tom @ CCL
    Tom @ CCL AKA: Yewen
    10 May 2010
    Why hello there!
  6. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    welcome :D also bindi isnt red anymore, does that mean we do not have to fear his banhammer?
  7. unknowngamer
    unknowngamer here
    3 Apr 2009
    I rate FSP.
    I've used them for years.
    I've had a few of these from scan.
    They used to put them on the "today only" for £30.
    At £60 they are OK, but at £30 they are AWSOME!
  8. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    If im honest the PSU i've got isnt good and isnt bad its simply mediocre, but does the job. Woudlnt like to SLI with it tho
  9. Fantus
    Fantus Nothing to see here...
    25 Jun 2010
  10. bagman
    bagman Minimodder
    18 Apr 2009
    welcome fsp look forward to seeing your new range of psu's
  11. Repo
    Repo What's a Dremel?
    12 Jan 2011
    I had a couple of FSP's a long time ago (read Althon 1800+ I think). They were pretty good pieces of kit :)
  12. Tealc
    Tealc What's a Dremel?
    6 Oct 2010
    I have a couple of FSP PSUs.
    I have one of those new FSP Aurum 700W PSUs installed in my machine and it's greta so far. Was sent to me by FSP direct from Taiwan as a competition win.
    I also have a OCZ SXS 600W which is FSP OEM and that's been solid for 2 years.
    A little bit on the noisy side if I'm honest but then I do have a reasonably quiet computer.
  13. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    Welcome!
  14. subtec
    subtec drawing boxes
    4 Nov 2010
    Can we make requests? I want to see a 500w+ SFX PSU.... like the Silverstone ST45SF, only, you know, not so janky (squeaks'n'clicks dontchaknow).
    Maybe some higher wattage (400w+) flex/ITX/1U PSUs (e.g., ~40x80x150mm), too.
  15. Sabrina@FSP
    Sabrina@FSP What's a Dremel?
    1 Mar 2011
    Hello!
    If you look into our website http://www.fsp-group.com/english/1_product/2_detail.asp?mainid=1&fid=57&proid=591, you will fined FSP400-60GHS. This is exactly same PSU you mentioned. We also make 300W or 450W for the same form factor.
    And for 400W+ 1U PSUs, 300/350/400/460W are the main stream we found in UK. You can find upto 700W 1U PSU from our website. http://www.fsp-group.com/english/1_product/1_list.asp?mainid=2&fid=141
    We don't do too high watt for ITX due to the spec requirement. Most people who use ITX PSU for their chasiss don't require too much power.
    Hope it helps!:)
