Case Mod - In Progress Obsidian Carnage
Discussion in 'Project Logs' started by Cygnitr0n, 3 Apr 2012.
  1. Cygnitr0n
    Cygnitr0n What's a Dremel?
    29 Aug 2011
    Hello Readers from the Bit-Tech Forum,
    I'm building a new system for myself with the new Asus Maximus IV Gene-Z, the Obsidian Carnage.
    My name is Stef (eng: Steve) and I'm from Holland and living in a town called Enschede.
    It will be a Game-PC with a fat OC tuning! I didn't want a big tower so I looked arround for a mid tower. With this mATX motherboard, a Big Tower will lose the effect on a little motherboard. And there will be to much space. Space I don't want or need. So that why I bought the Corsair 650D.
    I wanted a nice Case with fine lines in it. No "tierelantijnen" so as we call it in dutch. Corsair Obsidian 650D.
    This build has no known plan, and I am still figuring out what to tho with this 650D. So I will update every once a while. I'm not gonna bother you anymore with lame text. See for yourself.
    PC Hardeware:
    Intel Core i5 2500K
    ASUS Maximus IV Gene-Z
    EVGA GTX560Ti FPB (2x)
    Corsair Dominator DDR3-1600 CL9 16Gb
    OCZ Vertex 2 Extended 60GB
    Samsung Spinpoint F3 1TB (2x)
    Lite-On iHBS112-37
    Corsair AX850 Watt
    Cooling Materials:
    EK-WB HF Acetal
    EK-MOSFET Max IV Gene - Acetal+EN Nickel
    EK-RAM Dominator X4 - Acetal + EN Nickel
    EK-TUBE 250 Advanced
    EK-CoolStream RAD XT 120
    EK-CoolStream RAD XT 240
    EK-FC560 GTX - Acetal + Nickel -EN- V2
    KOOLANCE PMP-450 D5
    Bitspower D5 Modkit
    Bitspower TOP Acetal
    DEMI WATER
    Killer Coil 99.9% Silver
    Extra Cooling parts:
    EK-PSC Schroeffitting Black Nickel
    EK-CPU Easy Mount HF - Black
    Tygon R3400 - HighFlow - 3/8 ID - 1/2 OD - Black
    Bitspower G1/4 Matt Black Low Profile Stop Fitting BP-MBWP-C09
    Bitspower Crystal Link Tube For 2-Slots (SLI/CF) BP-CLTAC-S3
    Bitspower Schroeffitting Paar - G1/4 (2 stuks) Matt Black
    Bitspower G1/4 Temperature Sensor Stop Fitting
    Scythe Gentle Typhoon 120mm 1850rpm
    Scythe Slip Stream 120mm 2000RPM Slim
    Extra Materials:
    MDPC-X Sleeving
    Led's by wwwicked Red
    120MM Scythe Fan Guard12 SFG12-SL
    List can still be updated :)
    U can find more pictures or builds at www.cygnitr0n.nl
    Again a new package!
    So, and here we begin, screwing the nice Mosfet off (sorry that u have to go m8)
    And cleaning everything with the Artic Cleaning Set.
    This is a beautifull piece of EK. The Acetal Mosfet Block.
    And the CPU getting the Acetal Top <what a work! $%(%# rubber>
    EK-CPU Easy mount, very nice!
    Tygon Black Tubes, keeping it black.
    And for just a little modification, I made the stickers for the RAM with aan ROG look.
    There they are.
    The first one done :D
    and the rest..
    And this is how it looks on an Asus Maximus IV Gene-Z.
