News OCZ launches fastest 4GB DDR2 kit
Discussion in 'Article Discussion' started by CardJoe, 14 Apr 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Naberius
    Naberius What's a Dremel?
    20 Nov 2006
    I can't see the advantage of buying these over 4x 1gb dimm's, they look to wide for most motherboards to accept 4 of them so you are limited to 4gb anyway.
  3. Guest-16
    Guest-16 Guest
    They aren't too wide and not every board overclocks using 4x1GB sticks as much as just a pair of DIMMs.
  4. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
  5. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Sheesh! Makes me wonder how much these things weigh. Thoughts of them falling out of the slots from their own weight, lol.
  6. TreeDude
    TreeDude What's a Dremel?
    12 May 2007
    Man the tubes necessary for 2 sticks of these. It would make a mess of your nice tubing having to run that much.
    not to mention that it has been proven in benchmarks that the actual performance difference between the lowest speed RAM (DDR2 667) and the highest (DDR3 1333) is at max 10%. I bought 4gb of DDR2 800 @ 5-4-4-12 for $80. A strait conversion for mrb's link puts this kit at $277. That is over 3 times the prices for a 10% gain.
  7. eternum
    eternum *blam* shotgun fanhole
    14 Oct 2007
    A lot of people would pay 3 or maybe even 4 or 5 times as much for a 10% performance gain - it just depends on what corner of the enthusiast community you fit into and what components you are talking about. I do like that the companies are trying to innovate, though. It may not always result in practical products, or in value for money, but it certainly pushes things forward.
  8. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    sweet I have been waiting for something like this well now I just have to sit and wait. ^_^
  9. boggsi
    boggsi What's a Dremel?
    30 Aug 2005
    They aren't necessarily being brought for the increase in memory benchmarks. The article states that if you want to overclock your cpu into extreme speeds, you need your memory to be able to take the FSB. Lifetime warranty with over voltage protection... that's pretty sweet!
  10. BigPoppaJNutZ
    BigPoppaJNutZ Beyond the Dremel...
    14 Feb 2008
    Damn those look big!
Tags: Add Tags
