Windows Odd Recycle Bin corruption error - SOLVED
Discussion in 'Tech Support' started by Shirty, 29 Apr 2015.
  1. Shirty
    18 Apr 1982
    I cloned my work OS on to an SSD yesterday, and it's working flawlessly but for one issue - the recycle bin.
    If I try to recycle any file from my desktop (stored on a network share) I get the following error:
    What I did yesterday was to resize the original partition so that it would fit on the SSD (using Acronis Disk Director boot CD). I then cloned the drive using FarStone DriveClone free as I've had good success with this in the past.
    Post 1st boot I switched off defragging & indexing and checked TRIM.
    Things I have tried so far include running chkdsk, sfc, startup repair and deleting the $RECYCLE.BIN folder, but no problems have been detected and nothing has worked. If I can't solve it then I'll either learn to live with it or rebuild the machine, but it's a puzzler.
    Any ideas?
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    Not seen that before
    Is it only on your desktop?
    Have you tried another user? try another user - if it works, trash your profile and make a new one.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Could try deleting it from the command prompt, failing that maybe one of those programs that delete files on a reboot would clear it.
  4. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Hey Shirty, I don't recall ever seeing this before but here are a couple of links that my Google Fu found.......
    http://www.thewindowsclub.com/recycle-bin-is-corrupted-windows
    https://support.microsoft.com/en-us/kb/2394521
    Are you on redirected folders? If so then I doubt an offline removal would work. One last thing to try......
    From an elevated command prompt
    rd /s /q C:\$Recycle.bin
    Deletes the corrupted Recycle Bin, then just restart ;)
    Note: swap "C" for any other drive letter, that may have a corrupted Recycle Bin
  5. Shirty
    18 Apr 1982
    Protip Margo, the profile is 8 years old now so time for a fresh start.
    Corky, I can directly delete files OK, its just I can't recycle them.
    Pookie, tried with no luck - it's got to be profile related.
    Will post back with success story :)
  6. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I've seen this before, but it was files restored from a True Image backup. I found booting from parted magic (or something similar that has ntfsprogs installed) and running ntfsfix on the drive fixed it. Admittedly the files weren't on a network share.
  7. Corky42
    30 Oct 2012
    Forget that, just re-read the OP.
  8. Shirty
    18 Apr 1982
    Decided to scrap the whole thing and do a fresh build, I have a spare machine I can use.
  9. Margo Baggins
    28 May 2010
    Such an alpha. Good choice.
  10. Shirty
    18 Apr 1982
    It lives, suspect it was the clone job playing with my permissions.
