Modding Oil Cooled ?
Discussion in 'Modding' started by JesterQ, 12 May 2005.
  1. JesterQ
    JesterQ What's a Dremel?
    15 Jul 2004
  2. fieroloki
    fieroloki What's a Dremel?
    3 Jan 2004
    Yup, its old school...Mineral oil.....Its non-conductive.
  3. JesterQ
    15 Jul 2004
    First time i've seen it .. still mad thou.
  4. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    I did that once.. it was my first "mod"
    looks really cool when u lower a running fan into the oil
  5. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    Did it actually cool at all?
  6. phuzz
    phuzz This is a title
    28 May 2004
    I read it was just plain old veg oil, just to prove that it didn't need anything special, and I'm not sure how cool it got, but apparently it was dead silent, except for the HD's
  7. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    how about using veg oil in watercolling instead of water
  8. OdDBaLL_MoD
    OdDBaLL_MoD Always planning something...
    13 Sep 2004
    Maybe be too thick, then again, maybe a more powerful pump might do it?
  9. Springs
    Springs Boing boing
    29 Aug 2004
    omg first looked at this and thought how the f* does that not blow up.... cool really... wounder if it actually works...
  10. furqan
    furqan What's a Dremel?
    2 May 2004
    What happens if the oil heats up???
    Does it boil??
  11. Malvolio
    Malvolio .
    14 Dec 2003
    If the computer gets hot enough to where it starts boiling the oil, you've got a lot more serious concerns ;)
  12. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    /me puts some in pauls watercooling system
  13. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    what type oil do you need to do this ?
  14. bahgger
    bahgger Minimodder
    13 Apr 2005
    Oil that boils at approximately 40 degrees Celcius will do perfectly.
  15. nick01
    nick01 What's a Dremel?
    6 Nov 2004
    It looks like some off-the-shelf transformer oil to me. I give it two months before it has taken all plasticizer out of the PVC and many other plastic components. Next time some one touches anything it will fall apart.
  16. Gascan1888
    Gascan1888 What's a Dremel?
    15 Dec 2004
    that would actually be pretty cool, if he goes to remove it and it all falls apart !! :D
  17. mobius9
    mobius9 Minimodder
    4 May 2004
    heh, that would be a great "wtf" moment to see.
  18. Who_me_33
    Who_me_33 What's a Dremel?
    26 Oct 2004
    would the circuit boards be damaged, or just the components, and cards, and pci slots. Would be a good moment to se.
  19. spike12291986
    spike12291986 What's a Dremel?
    20 Sep 2004
    no no no!!!
    ok this hase been done before, this idea hase been around for age's and it still sucks. the pump you need to move the oil with would draw about 4 to 6 amp's now if you hade a pump like that hooked to your water pump you would never see the temp rize...and yes i have not just red about the oil comp i used one for about a month but when i found out how much it cost to run it there was just no point....hope this helps some of you new guys/girls well maybe one 1girl out there....good luck and happy moding
  20. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Hi
    the viscosity of the oil is FAR to high to run in a normal watercooling loop without investing in a better/more powerful pump
    im tempted to do this with an older PC, but im debating using a different method, going along with using some of the non-conductive water stuff (pleurocarbon or something) and have a waterloop that isnt just a loop, so basically its normal air cooling, but instead of fans have the non-conductive water being sprayed over the heatsinks, will be more for fun than for seriousness!!! would be cool to make an oil running pc ;) just for a laugh, ive got loads of old p3/p2 stuff im not using ;)
