Modding Ok, so I was bored..
Discussion in 'Modding' started by :: kna ::, 20 Aug 2001.
  1. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    and HAx0RR3d my USB hub.. then I got stuck as where to put it.
    so..
  2. Oddball
    Oddball What's a Dremel?
    20 Mar 2001
    lol, i like it, i like it a lot :D
    go on, how long did that take ya ;)
    oddy
  3. crazylegs
    crazylegs What's a Dremel?
    19 Aug 2001
    your mad you are
    but its funny :D
    what happens when it gets dropped and broken into pieces,
    rebuild it as a house?
  4. Oddball
    20 Mar 2001
    Re: your mad you are
    then he gives it back to the children ;)
  5. :: kna ::
    15 Mar 2001
    Lol, no the legos mine.. I bought it in a fit of stupidity when I was passing the lego shop.
    Wonder if I can put my 100Mb switch in there too.
    Hmm.. :D
  6. SuperScrubber
    SuperScrubber Mad Chemist.....buwahahaa
    12 Mar 2001
    LOL schweet!!!!
    .........you have way too much time dood!!! :D:D
  7. RTT
    RTT #parp
    12 Mar 2001
    kna,
    get a techinics motor kit and add some wheels and a motor and drive it around!!!
    or make a truck chassis type thing and mount it on the back and then add motors and stuff!!!
    you know you want to ;)
  8. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    dont encourage him, next thing well hear is that hes gone down to the local toyshop and bought all the lego kits so that he can build a lego case!!!
  9. RTT
    RTT #parp
    12 Mar 2001
    ive gotta lego case, i'll scan some pics in of when it existed :D
    kna, also put some lego men on top fighting and stuff :D
  10. Koolvin
    Koolvin The Modfather
    12 Mar 2001
    smart :)
  11. tigermain
    tigermain What's a Dremel?
    24 Mar 2001
    Where do you get these ideas from ????
