Displays ok this is stupid
Discussion in 'Tech Support' started by Ryu_ookami, 27 May 2009.
  1. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    this is going to sound really stupid but I'm unable to disable my secondery monitor
    if i click display properties and then take the tick out of extend my windows desktop to this monitor the moment i click apply the PC re-boots where it then re-detects the monitor and once booted uses both monitors again.
    If I try and disable the monitor use the catalyst drivers the moment it tries to disable the monitor the computer re-boots and then restarts again.
    Its driving me insane I know that I could just unplug the monitor from the back of the PC but i don't want to do that ever time I need to disable the monitor any ideas would be really really helpful
  2. RADCOM
    RADCOM What's a Dremel?
    21 Mar 2005
    what version of the catalyst drivers are you using?
  3. Ryu_ookami
    11 Mar 2004
    apparently its version 2009.0203.2228.40314 of the ati catalyst control center w
