Modding Old Monitor Mod O_O
Discussion in 'Modding' started by Dash, 5 Nov 2002.
  1. Dash
    Dash What's a Dremel?
    24 Sep 2002
    I have a old 15 inch monitor that just sits in my closet and I want to mod it.
    Right now I am leaning toward taking out the inards and using the shell with some glass to make a fish monitor bowl.....Unless some one has some cooler ideas for it
    :D
    Thanks
    -Dash
  2. Kargin
    Kargin Overdose . . .
    18 Sep 2002
    Spend a few bucks on a cheap PCI video card and go dual monitor:hip:
    Another idea though is to take the shell, and replace it with a plexi casing, so that you can use the shell for your fish tank thing, and then still have dual monitors. You could put in soem lights and maybe even tint parts/all the case or use smoked plexi, use different colored plexi, etc.
    Build a Jacob's Ladder with it.
  3. Dash
    24 Sep 2002
    The plexil monitor sounds good and the fish can still have their home........thanks :rock:
  4. cderalow
    cderalow bondage master!
    23 Jan 2002
    on a side note dash... it looks like you've got your window molding in backwards??? or is the locking strip on the inside?
  5. djengiz
    djengiz Pointless.
    16 Aug 2002
    Blow it up on bonfire night?
