Graphics Omega driver
Discussion in 'Hardware' started by quadmodz, 3 Aug 2005.
  1. quadmodz
    quadmodz What's a Dremel?
    9 Oct 2004
    A friend of mine cannot install the omega driver on Ati Radeon 9250. Which mean that the driver is not compatible? but on the requirements shown in the omega driver site, that ati radeon 9250 is compatible on that driver
  2. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    Well, the driver's telling you it isn't compatible with the hardware it's finding. Is it a normal out-of-the-box 9250 or did it come built in a pc?
  3. quadmodz
    9 Oct 2004
    no the video card was not a built in. My friend video card was a ATI RADEON 9250 128mb /64bit. Until now. he try to install that driver, but it always failed. :(
  4. atanum141
    22 Jul 2004
    how does it fail???
    what does it say??
    ive installed omega drivers countless time ....even last night....ive never had probs....
    has he even tryed to install original ATi drivers??
    also u can use a tool called"driver cleaner" to get rid of annoying old driver files so that ur current newer drivers dont have a problem to install or function properly.
  5. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    If it just starts complaining at you about Microsoft Digital Driver Signing, just select "Continue Anyway". Not something to worry about. Don't know if that's the problem you're having, but I know Windows complains about all Omega drivers, all hacked drivers for that matter :).
  6. smoguzbenjamin
    6 Sep 2004
    Gotta have winXP pro for that last time I checked. XP Home just aborts the installation.
