Windows One stop set for new PCs
Discussion in 'Software' started by droitwichdosser, 30 Oct 2009.
  1. droitwichdosser
    droitwichdosser New Member
    25 Apr 2009
    Dont know whether anyone has tried this in the past, but it looks useful...
    http://ninite.com/
    hopefully be of use to someone
  2. oatey4519
    oatey4519 can't be arsed...
    5 May 2009
    I've seen it being talked about...
    Doesn't look too bad does it.
    Will bookmark this.
    Saves storing out of date files etc
    Cheers
    +1 Rep
  3. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Nice, looks handy, if only i knew about it a couple of months ago hehe.
    Bookmarked for future use :)
  4. AngusW
    AngusW mmm
    20 Oct 2009
    Wow that does look handy and it has like 95% of the utilities i'd put on a fresh install.
  5. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Nice! +rep
  6. erratum1
    erratum1 New Member
    30 Apr 2009
    Nice !:D
  7. droitwichdosser
    25 Apr 2009
    least its helped a few 8D
  8. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Looks very handy.
    I can see only one problem though.
    It says that the default install paths are chosen for you automatically.
    This would mean that I wouldn't want to use it, as all my apps go onto my D drive.
    If you could choose the install location when you run the ninite installer, then it'd be perfect.
  9. haddow64
    haddow64 New Member
    24 May 2009
    I have just used it after formatting the gf's laptop, worked perfectly. But as Cerberus says it will only install to the c drive, which limits it to basc setups.
  10. Mr Happy
    Mr Happy 4 8 15 16 23 42
    25 Apr 2009
    Great, love it + rep from me
  11. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    Used it
    loved it
    love you
    great find
    enough said!
  12. aLtikal
    7 May 2008
    hmmm got a gripe with this.
    It wont let you choose where to install everything too :( which is no good for me as i have to install everything on a seperate partition :(
  13. Cerberus90
    23 Apr 2009
    Thats what I said just 4 posts up.
  14. Akava
    Akava Lurking...
    28 Jul 2007
    Seems like a great piece of kit, I think I'm going to give it ago later on my Netbook; I still haven't installed anything on the Windows 7 RC partition. :thumb:
    That is a shame to hear, but I think for a lot of people this won't be a problem, lets just hope they are planning to add the ability to change the install position in future releases. :clap:
    EDIT: A friend reminded me of something; you could just edit your registry to change the default windows installation path. Obviously at your own risk.
  15. Cerberus90
    23 Apr 2009
    Ah, that looks simple enough.
    Probs try that at some point.
    Just had a look in there on Win7, and there ProgramFilesDir, Program Files(x86 Dir, and ProgramW6432Dir.
    God knows what the W6432 one is for.
  16. Akava
    Akava Lurking...
    28 Jul 2007
    Your using a 64Bit copy of windows I would assume; if so then it is the second program files folder path.
    Programs Files / Programs Files (x86)
    ........ 64Bit ................ 32Bit ........
