I tried putting OpenWRT (squashfs) on my Belkin F5D7230-4 (v1444), and it doesn't work. Can anyone help? Below is what the text terminal shows: Decompressing..........done Here we try to capture the default reset button: None. CFE version 1.0.37 for BCM947XX (32bit,SP,LE) Build Date: Mon Apr 19 18:19:30 CST 2004 (denny@dnylinux) Copyright (C) 2000,2001,2002,2003 Broadcom Corporation. Initializing Arena. Initializing Devices. et0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.60.9.0 CPU type 0x29007: 200MHz Total memory: 0x800000 bytes (8MB) Total memory used by CFE: 0x80300000 - 0x80434A50 (1264208) Initialized Data: 0x8032EB60 - 0x80330E90 (9008) BSS Area: 0x80330E90 - 0x80332A50 (7104) Local Heap: 0x80332A50 - 0x80432A50 (1048576) Stack Area: 0x80432A50 - 0x80434A50 (8192) Text (code) segment: 0x80300000 - 0x8032EB60 (191328) Boot area (physical): 0x00435000 - 0x00475000 Relocation Factor: I:00000000 - D:00000000 Device eth0: hwaddr 00-11-50-0D-BC-98, ipaddr 192.168.2.1, mask 255.255.255.0 gateway not set, nameserver not set Reading :: Failed.: Timeout occured Loader:raw Filesys:raw Dev:flash0.os File: Optionsnull) Loading: .. 3704 bytes read Entry at 0x80001000 Closing network. Starting program at 0x80001000 CPU revision is: 00029007 Primary instruction cache 8kB, physically tagged, 2-way, linesize 16 bytes. Primary data cache 4kB, 2-way, linesize 16 bytes. Linux version 2.4.30 (wbx@ux-2y02) (gcc version 3.4.4) #1 Wed Nov 23 22:35:53 CET 2005 Setting the PFC value as 0x15 Determined physical RAM map: memory: 00800000 @ 00000000 (usable) On node 0 totalpages: 2048 zone(0): 2048 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: root=/dev/mtdblock2 rootfstype=squashfs,jffs2 init=/etc/preinit noinitrd console=ttyS0,115200 CPU: BCM4712 rev 1 at 200 MHz Using 100.000 MHz high precision timer. Calibrating delay loop... 199.47 BogoMIPS Memory: 6192k/8192k available (1395k kernel code, 2000k reserved, 100k data, 80k init, 0k highmem) Dentry cache hash table entries: 1024 (order: 1, 8192 bytes) Inode cache hash table entries: 512 (order: 0, 4096 bytes) Mount cache hash table entries: 512 (order: 0, 4096 bytes) Buffer cache hash table entries: 1024 (order: 0, 4096 bytes) Page-cache hash table entries: 2048 (order: 1, 8192 bytes) Checking for 'wait' instruction... unavailable. POSIX conformance testing by UNIFIX PCI: Fixing up bus 0 PCI: Fixing up bridge PCI: Fixing up bus 1 Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Initializing RT netlink socket Starting kswapd devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au) devfs: boot_options: 0x1 JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB. Squashfs 2.1-r2 (released 2004/12/15) (C) 2002-2004 Phillip Lougher pty: 256 Unix98 ptys configured Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled ttyS00 at 0xb8000300 (irq = 3) is a 16550A ttyS01 at 0xb8000400 (irq = 0) is a 16550A Software Watchdog Timer: 0.05, timer margin: 60 sec Amd/Fujitsu Extended Query Table v1.0 at 0x0040 number of CFI chips: 1 cfi_cmdset_0002: Disabling fast programming due to code brokenness. Flash device: 0x200000 at 0x1c000000 Physically mapped flash: Couldn't find root filesystem Creating 5 MTD partitions on "Physically mapped flash": 0x00000000-0x00040000 : "pmon" 0x00040000-0x001f0000 : "linux" 0x00000000-0x00200000 : "rootfs" 0x001f0000-0x00200000 : "nvram" 0x00000000-0x001f0000 : "OpenWrt" Initializing Cryptographic API NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP, IGMP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 512 bind 1024) ip_conntrack version 2.1 (5953 buckets, 5953 max) - 320 bytes per conntrack ip_tables: (C) 2000-2002 Netfilter core team NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. NET4: Ethernet Bridge 008 for NET4.0 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com> All bugs added by David S. Miller <davem@redhat.com> jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000000: 0x0001 instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000008: 0x1fff instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000000c: 0xffff instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000010: 0x4024 instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000014: 0x1fc0 instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000018: 0x082a instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000001c: 0x0016 instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000020: 0x0008 instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000024: 0xbfc0 instead jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000028: 0x8000 instead Further such events for this erase block will not be printed ... (jffs2 errors repeat many times) Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes Kernel panic: VFS: Unable to mount root fs on 1f:02
The Belkin Wireless G Router ok first why do you need to run that a Linux distribution for wireless on your router ,you find that you can do a lot with the original softwere that Linux softwere run´s best on a linkses router,The Belkin Wireless G Router is good .
