Graphics Opinions please, I think I chose well?
Discussion in 'Hardware' started by Thermal5, 6 May 2009.
Which graphics card would you honestly have chosen?
Poll closed 13 May 2009.
  1. Gainward GTX 260 Golden Sample
    40.0%
  2. BFG GTX 260 OC Maxcore
    60.0%
  1. Thermal5
    Thermal5 R.I.P
    3 May 2009
    Hey all,
    After getting some much appreciated advice off smc8788 in this thread http://forums.bit-tech.net/showthread.php?t=167795 I decided to pay a bit more of a premium because of what I was told and from what I had read online that BFG make excellent cards and that their warranties are excellent.
    Now what would anyone who reads this have done when confronted with making a decision about which card to buy out of the 2 below, the Gainward card is also overclocked like the BFG one and has quite a bit higher GPU core and Memory speed than the BFG but something tells me the BFG card will be the better card! Specs below.
    Gainward = 625MHZ GPU
    BFG = 590 MHZ GPU
    Gainward = 1296 MHZ Shader Clock
    BFG also = 1296 MHZ Shader Clock
    Gainward = 1100 MHZ Memory Speed (2200 MHZ effective)
    BFG = 999 MHZ Memory Speed (1998 effective)
    The Gainward also has a dual fan but does this really make a huge difference in temperatures? Because I don't really know, all I know is that 2 fans is probably better than 1 or does it depend on the actual cooler itself on graphics cards and could a single fan graphics card do the job equally as well??
    Anyway the links to the 2 cards are below.
    Gainward http://www.novatech.co.uk/novatech/specpage.html?GW-265
    BFG http://www.novatech.co.uk/novatech/specpage.html?BFG-MC260
    I honestly do believe the BFG will be the better card but I always appreciate more input from other experienced users.
    Thank you.
    P.S) The price difference not including delivery between the 2 cards is roughly £15, the BFG card being the more expensive
    P.P.S) My PSU is the ThermalTake Toughpower 600 Watt with Four +12V rails(12V1, 12V2, 12V3, 12V4) (combined loading of 48A), that should be more than enough to power the card shouldn't it combined with my Core 2 Duo E8400, 4 GB Ram, 2 SATA Hard Drives and a DVD Rom Drive and DVD Writer (both SATA as well)
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    I would go for the Gainward, actually. I love the dual fan..
    BFG is a great brand though, awesome warantee. Overclocks don't really matter in terms of purchasing, I bet the BFG will reach those clocks, and the difference will be small anyway.
