Scratch Build – Complete ⭐ Oracle Project
Discussion in 'Project Logs' started by SaaintJimmy, 20 Feb 2019.
  1. SaaintJimmy
    SaaintJimmy Staff Lover of bit-tech
    6 Apr 2016
    Hey folks! I'm finally back with a fresh new project for you, this time a mITX scratch build based on Oracle, a Persona 5 character.
    This project is brought to you by *me*:
    MSI Italy - Enermax Italy - Adata XPG Italy - PC Frog SRL Milano
    Let's start off with some hardware pics. These include: MSI GTX 1070Ti Gaming X, XPG Spectrix D80 and SX950U 500Gb, Enermax SFX Revolution 650W and LiqFusion 240 with T.B. RGB Fans, Ryzen 5 2400G.
    And now the real stuff. First thing to do is create a base structure from aluminum profiles of various type: flat, squared, L-shaped etc.
    And rivet everything together
    Doubled it
    Some preliminary test fitting
    Internal mounts for acrylic fan and radiator holders
  2. SaaintJimmy
    6 Apr 2016
    First episode of the video worklog. English subtitles available!
  3. SaaintJimmy
    6 Apr 2016
    Update time!
    Rad and fans mounting panels completed
    Original layout I had in mind
    New layout after rotating the case to drill some holes and noticing it was way cooler like this hahaha
    Internal cover panels. The one above the graphics card also helps the card to stand in place and not move around
    _Prometheus_ likes this.
  4. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    No doubt this is gannna end up another SJ classic :rock: love the layout and mats :)
    SaaintJimmy likes this.
  5. SaaintJimmy
    6 Apr 2016
    Second part of video worklog is on:
  6. SaaintJimmy
    6 Apr 2016
    Man those were some busy days... but I'm here again for an update!
    Today we're taking a look at some final tweaks before the paintjob starts.
    All the thread inserts for the external panels
    UV green panels and other clear and to-be-painted panels
    Design for fan vents
    Added an aluminum flat strip to have a better structure for the acrylic panel that will hold the PSU
  7. Cheapskate
    13 May 2007
    Looking good. :D
    Not much room for a HDMI cable. Are you planning to add legs?
  8. SaaintJimmy
    6 Apr 2016
    The whole case is going to be lifted so there will be plenty of room for any I/O cable :D
  9. warboy
    warboy Insane modder
    24 Nov 2011
    It's already cool ;)
  10. SaaintJimmy
    6 Apr 2016
    Here I am with a huuuge update!
    I couldn't find an interesting way to make the feet of the case so I just went all out and made this out of 8mm acrylic, aluminum L-profiles and pine wood:
    And no it's not an Omen X, as a lot of people said. The only thing in common is the cube form hahaha
    Paintjob starts
    Decided to leave central acrylic piece clear so I polished the edges
    Swapped the motherboard for an MSI H310I PRO since the previous one was dead
    Stencils on the internal panels
    Majority of the hardware is in
    UV LEDs all around the top and bottom sections
    UV lighting test
    Cheapskate likes this.
  11. storm-83
    storm-83 Minimodder
    7 Nov 2014
    being a sucker for uv - this ticks a lot of my boxes so far
    will be impatiently awaiting further updates!
  12. SaaintJimmy
    6 Apr 2016
  13. Cheapskate
    13 May 2007
    Can you slip an extra strip of LEDs over the top edge of the motherboard plate? I think that would look sick. :D
    Love it!
  14. SaaintJimmy
    6 Apr 2016
    Thank you! I should be able to do that, I'll test it and see if it's worth it :D
  15. kim
    kim hardware addict
    10 Jan 2016
    it quickly took a very elegant shape :thumb:, panels are awesome
  16. SaaintJimmy
    6 Apr 2016
    Thank you very much!
  17. SaaintJimmy
    6 Apr 2016
  18. SaaintJimmy
    6 Apr 2016
    Unveiling Oracle Project.
    A scratchbuild based on the Persona 5 character, Oracle.
    Taking part to the builds.gg stock cooling contest:
    https://builds.gg/contests/the-builds-gg-stock-cooling-showdown-aio-cooling-division-5
    Specs:
    i3-8350k
    MSI H310I Pro
    ADATA XPG D80 16Gb 3000Mhz
    ADATA XPG SX950U 480Gb
    Enermax LiqFusion 240
    Enermax Revolution SFX 650W
    Enermax T.B. RGB 120mm
    Huge thanks to the sponsors of this project:
    MSI Gaming
    ADATA XPG
    Enermax
    Pc Frog Srl
  19. kim
    kim hardware addict
    10 Jan 2016
    stunning how you built that splendid mod so quickly...the pannels are really great :clap:
  20. Cheapskate
    13 May 2007
    It came out absolutely lovely.
