News Oracle warns of critical Java vulnerability
Discussion in 'Article Discussion' started by Gareth Halfacree, 24 Mar 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. theshadow2001
    3 May 2012
    Perhaps the "write once run anywhere" slogan was actually aimed at malware writers.
  3. Wwhat
    Wwhat Minimodder
    2 Oct 2005
    It's sort of funny to use the term 'remote code execution' since that is the idea with a lot of runtime code like Java.
    Perhaps 'malicious' or 'above security level' or some such should be in that term.
  4. Alecto
    Alecto Minimodder
    20 Apr 2012
    Java Update popped up yesterday, I imagine this was the bug fix.
    I do have one question though: can systems be infected using malicious code on webpage kind of attack when their browser Java plugin (for Firefox in my case; I've got two plugins here which appear to be related to Java, one is Java(TM) Platform SE 8 and the other is Java Deployment Toolkit) is set to either
    A - always ask before running the plugin (and the user selects 'no')
    or
    B - never execute plugin
