Overclock / Temps
Discussion in 'Hardware' started by alacritous, 18 Jan 2005.
  1. alacritous
    alacritous What's a Dremel?
    1 Jan 2004
    Hello,
    First, before I overclock, I would like to know what temperatures are normal. My CPU is running at 49C when just browsing the internet. Here are the specs from EVEREST.
    CPU Type Intel Pentium 4HT, 2600 MHz (13 x 200)
    CPU Alias Northwood HyperThreading
    Original Clock 2600 MHz
    Core Voltage 1.475 - 1.55 V
    I/O Voltage 1.475 - 1.55 V
    Typical Power 38.7 - 89.0 W (depending on clock speed)
    Maximum Power 49 - 109 W (depending on clock speed)
    I don't think I really want to up the voltages because I don't want to break it or do something that will mess it up.. I just want to overclock as much as I can without upping the voltages.
    Alacritous
  2. alastor
    alastor Minimodder
    6 Sep 2004
    49ºC seems a little on the high side when there's not alot of load, so before you do anything you might want to find yourself some better cooling. But when you do, as its a Northwood you should be able to get a pretty decent overclock out of it without even raising the voltage too much.
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Yip, should be able to get to ~ 3ghz with little to no increase tbh, shouldnt affect temps too much either... those are a little on the high side, what case cooling are you running?
  4. alacritous
    1 Jan 2004
    I don't know any specifics, but I just have a normal fan with CPU grease. There is a little "duct" or whatever it's called that allows the air to go directly out a tube outside the case.
    Is that what you mean?
    BTW, the case is 28C.
    Alacritous
  5. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    If the case is 28C, 49C nearly idle is way too high. I would say grab a better hsf combo.
  6. AngelOfRage
    AngelOfRage Minimodder
    8 Dec 2004
    that does seem abit high. Im running a P4 3.4HT (Prescott) at 35.5 C while idling (well web browsing and running Winamp...) with a case of 25.0 C. admittidly i did replace the stock cooler as soon as i got it. im now running a Gigabyte 3D cooler on there and its made a massive difference.
  7. alacritous
    1 Jan 2004
    Damnit see I just got a HSF... I guess I got a cheap one.
    I couldn't do anything else to get it to run cooler?
    edit: Is there anyway I can make the fan go faster? I mean I'm sure I can, but does it run default at the max?
    Alacritous
  8. Mister_Tad
    27 Dec 2002
    the fan as it is will be running at full speed (technically you can make it run faster, but it probably wont last very long)
    what motherboard do you have, are you sure that it has overclocking features?
  9. alacritous
    1 Jan 2004
    Oh yes I am sure it does.
    It is an IC7-G MAXII ADVANCE.
    The fan and heatsink and just normal CPU ones.
    Alacritous
  10. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
  11. alacritous
    1 Jan 2004
    Yup... lol
    Wow this sucks... See the thing is, which makes me even more mad is this: My friend gave me the CPU, but didn't have the HSF... so I bought it... WHY did I have to buy this sucky one??! lol
  12. Froggy
    10 Jun 2003
    Lol thats the stock heatsink, the one that comes with the CPU. Do yourself a favor and read some reviews and get a better heatsink.
