P4 3.0C 30 caps
Discussion in 'Hardware' started by barry_n, 16 Jan 2005.
  1. barry_n
    barry_n What's a Dremel?
    24 Aug 2004
    as the topic says, i have one of these coming my way and cant wait to start OC'ing it, xp-120 with a delta 120mm efe.
    the FPO of it is L401A, has anybody had any experiance with this particular batch, i know these clock real good in general but still pot luck as to how good u can get it.
    and i paid £105 for it, is that too much?
  2. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    If its a 30capper you should at least see 3.7ghz out of it, But I would water cool if I were you. My non 30cap p4 3.0c is doing 3.75ghz rock stable but im water cooling and my load temps are 33c i could do more probly but I dont wana breack it...
  3. barry_n
    24 Aug 2004
    cant afford watercooling, and the whole point of me hunting down a 30capper was because they run cooler... right ?
    its a SL6WU, anyway to tell if its a 1.4v version before recieving it ?
  4. GunDam
    GunDam Minimodder
    9 Feb 2002
    Barry N, where are u getting all these nice tastey CPU's from?!?
    1st a P4 2.8C ES and now a 30 capper!?!?!?
    I was out bid on a P4 2.8C ES today, by £2 :wallbash: it was reported to go up to 4.2Ghz!!!! :eeek:
  5. Pistol
    Pistol Guest
    How do you find the numbers you're getting on your proc...on the heat spreader or CPU-ID?
  6. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    you get them by the heatspreader on the chip/laser written stuff. I just got a 3.0 Northwood for 150 at Fry's electronic's in Concord California. It has D1 stepping but i havent checked out the readings on the chip itself, hopefully it is a 30cap :naughty:. Congradulations on your find, hopefully mine as well, will have the results tommorrow, when i finish encoding dvd's.
  7. barry_n
    24 Aug 2004
    GunDam ebay is your friend :D do a lot of googling, and a lot of "ask the seller" i got a 30 capper for myself and a friend both from ebay, his cost less (i wish i hadnt found it for him) mines from usa, thats the only drawback so i got 7 days till it gets here. his is from uk.
    Overclockers have the 3.2 northwoods, if you go into the store im sure they wudnt mind looking thru their cpu's to see if they got a 30 capper ;) ;)
  8. 1st time modder
    21 Dec 2003
    yea i have a damn 12 cap ( :waah: ), although i should get some nice pc-3700 to oc it (later since i just got it.
    Kind of of topic:
    Do you know by chance the stepping thing on other processers.
    Ie. my old 2.2B northwood gets to 3.0 easily with stock voltages (readout from the processer Q340A260).
