P4 Fan recommendations
Discussion in 'Hardware' started by Phil_Bks, 28 May 2003.
  1. Phil_Bks
    Phil_Bks What's a Dremel?
    13 Sep 2002
    Anyone able to offer advice on what fan to purchase for my new setup?, based around an ASUS P4P800 Deluxe / Pentium 4 2.6 (800) which I plan to moderately O/C....
    Don't really want to spend a fortune, so £20 ish?..
    Thanks in advance...
  2. CatKing
    CatKing What's a Dremel?
    10 Nov 2002
    does it include hs.
    if not, i would suggest spend a little more for a good hs and u can balance at quite/performance by choosing the fan.
    good hs worth the money and can last for years.
    i'm using a swiftech mcx462-u with tt smart case fan 2 with led light. my p4 2.4b @3g is running fine at 36c/48c while the cooler is spinning at 3000rmp
