P4 Mini-ITX Car PC
Discussion in 'Project Logs' started by chumbly_warner, 26 Feb 2004.
  1. chumbly_warner
    chumbly_warner What's a Dremel?
    28 Jun 2003
    My dream car is a Bannana yellow porche, but i cant really afford 1. I wanted a internet server and also a lan server for when i host lan partys, so i thought i could put a computer in a model porche shell. I looked at getting a 1Ghz Mini-Itx board from via, but if i was going to spend that kind of money i wanted something a bit faster than that. I was looking on the net when i found a P4 mini-itx motherboard, which will take up to 3Ghz. I just had 2 have 1, so i ordered that and a 80Gig hard disk and 512mb of ram and a 2.4Ghz processor. I went down to my local model shop for the porche shell and the wheels.
    I then had to figure out how to get it all to fit into the shell of the porche. I got some perspex from my old sixth form college and marked round the shell. Then positioned all of the components so the shell would fit on. I needed to raise the motherboard up so that i could put the powersupply under it, i used some nuts and bolts to hold the motherboard up. I had to take the case off the powersupply to.
    I am just going to have the pots i need out the back, so i got a wireless keyboard and mouse and mounter the reciever inside the car 2.
    This is where i am at now.
    I need to spray the shell, get the ard disk mounted, wheels working and then make the headlights come on and the indicators work when the power comes on and when the hard disk is working.
    Opinions please. :)
  2. Le Tordu
    Le Tordu What's a Dremel?
    16 Jan 2004
    A 2,4 GHz 996 ! Better than the original Flat 6 ! :hehe:
    Got a question ! Won't the heat of the P4 affect the shell ? :geek:
  3. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Well, if I'm not mistaken the shell of the car is Lexan, which is (I've found out) a pretty hard plastic. I even had a hard time cutting it. It splinters like heck, and I mean really tiny splinters. More like dust I guess. It's pretty heat resistant, unless you stuff a hardcore OC'd AMD in though ;)
  4. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    man thats really cool. What you could do. Is die the whole car in uv blue, then get a uv light inside it. That would look the nuts.
  5. Fr0z3n
    Fr0z3n What's a Dremel?
    21 Oct 2003
    Looks awesome. :rock: I wanna see what you do with this. :)
  6. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    OMG, that P4 heatsink seems so huge on a so tiny motherboard!!
    BTW nice car.... are you really sure about banana yellow??? :jawdrop:
  7. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    I did a car mod a while back and they are very fun :)
    What sized shell is that 200mm?
    Good luck with it :)
  8. raxxo
    raxxo What's a Dremel?
    24 Jan 2003
    Yup.. that's right... how would a RC racecar withstand the heat from a petrol engine if it's not heatresistant... the engines who runs on nitro that is...
  9. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Wow, the shell is bigger than I thought. You should get a model that has a sunroof, and use that as blowhole lol :cooldude:
    Keep up the good work! :thumb:
  10. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    hey dude! looks like this will be sweet - however - why not make the power LEDs the headlights, and the HDD activity the brake lights?
  11. ReFredzRate
    2 Sep 2002
    That's totally true indeed. I just remembered my old electronic RC car. It had a cooling block for the electronic motor in it. The motor stayed cold, but the block came close to 125 celsius... So Lexan is very heat resistant.
  12. Vo0Ds
    Vo0Ds Fake potato
    6 Feb 2004
    Wow that mobo is small, i like the UV idea but i hope you're going to keep the banana yellow :hip:
  13. Bentos
    Bentos What's a Dremel?
    12 Feb 2002
    tis looking pretty good ashers, cant wait to see it in real life over easter, cool.
    ooh, those rims are pretty similar to the ones on your corsa, oooh, clever.
    just wondering, but there doesnt seem to be any airflow for the stripped PSU, plus its under the mobo, any ideas on cooling it?
    Bentos
  14. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Thats what I did on mine its quite funky :D
  15. Tulatin
    16 Oct 2003
    cool. Also, route a fan to exhaust - so that you can hear a throughty roar when it runs :naughty:
  16. _frank`
    _frank` What's a Dremel?
    28 Feb 2004
    not bad, but a bit too colorful in my eyes ;)
    but keep on your work
  17. chumbly_warner
    28 Jun 2003
    I have now got all of the bits mounted on the perspex, the wheels are on, with the tyres. I just need to find a way of securing the shell on.
    Has any1 got a wireing diagram so i can run about 4 LEDs off of the power led on the motherboard (main lights) and 6 LEDs off the HDD activity 1 on the motherboard (indicators)? Also starting making a plate for the back where the extended ports will be, it will have a coaxial, s-video, monitor out, 1 usb, network and power plugs.
    I will get some pics up 2morrow.
    Ashley
  18. chumbly_warner
    28 Jun 2003
    Finally got these pics up, have been busy with coursework.
    Here is the new wireless keyboard & mouse i got 4 the pc, i have mounted the reciever inside.
    opinions?
    I have a 20x4 backlit blue lcd, do u think i should mount it in the windowscreen? :dremel:
    I am getting the shell sprayed, so should be done soon.
    Ashley
  19. noneuno
    noneuno What's a Dremel?
    2 Mar 2004
    Very nice. I'd love to see that thing actually be a gas-powered RC car also, but... another mod for another day! Looks very good.
    As far as the lcd being in the window, it doesn't look like you have the clearance. Also, the Porche's window is curved, the LCD flat. You'd probably have to cut the window to mount the LCD, and have the LCD coming out of the car a little bit. Not sure how that'd look. :) Nice job so far.
    PS I have a car mod project log coming soon... except my server is going in a real car. :naughty:
  20. ReFredzRate
    2 Sep 2002
    Looks pretty sweet! Will the car still be yellow? If yes, what will you be doing to the mouse and keyboard? If no, will you give it the same colors as the mouse and keyboard?
    And something else: Are you sure you've got enough airflow for the CPU in there?
    Besides those points, you've got a great computer there!!! :rock:
