Motherboards P8P67-M PRO
Discussion in 'Hardware' started by Sponge12349, 11 May 2011.
  1. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    Hi all,
    I was wondering whether the Asus P8P67-M PRO will overclock worse than just a P8P67. Reason being that it is on offer on today only for just £106.
    Thanks in advance! :)
  2. murraynt
    murraynt Modder
    6 Jun 2009
    Should overclock better as it has better power management. Unless you are referring to the p8p67 pro in which case it should be on par.
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    It is a great board and as MurrayNT says, will overclock better (or at least will be more stable) than the bog standard P8P67 due to better power management. In addition, it can do SLI and Crossfire whereas the P8P67 can only do Crossfire.
    Make sure you get the latest BIOS from the Asus website if you buy it.
  4. Sponge12349
    12 Apr 2010
    Thanks alot guys! :)
  5. murraynt
    murraynt Modder
    6 Jun 2009
    Oh yes. The first ones were very unstable. I should know.:wallbash:
  6. Ronaldo 9
    Ronaldo 9 Minimodder
    23 Jun 2010
    With Sandy Bridge it's more Chip dependant than anything TBH. Of course improved power phases will help but not as much as a golden chip IMO. Either way you will be having an Awesome OC. Also I recommend that you clear the CMOS before you first boot your PC and when you update the Bios clear it again.
  7. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    The Micro Pro version lacks DIGI+ VRM power management compared to the vanilla ATX so arguably it has worse power management unless I'm missing something here.
  8. kenco_uk
    28 Nov 2003
    I was looking seriously at this mobo too, particularly because of the price it's at. I'm waiting to see if Z68 delivers first.
  9. Sponge12349
    12 Apr 2010
    Bought it yesterday only to see another price drop on today only! :hehe:
