Electronics Panel Connectors
Discussion in 'Modding' started by Kickn, 28 Aug 2006.
  1. Kickn
    Kickn What's a Dremel?
    7 Oct 2003
    Okay - starting a new project and need to sort out some 24pin ATX connectors that are panel mount. Looking for the female version and some (if possible) nice male versions. Also some panel mount 4-pin molex (aka hard drive) and SATA connectors.
    Has anyone ever seen these or are they just normally glued to panel cut-outs?
  2. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    Are you talking about bolt on connectors? like that you can screw them into a panel, sorta like the usb ports you find on the front of some computers, or those back I/O panel ones that go on a PCI riser?
    If so I know for sure they make the SATA ones for external hd's, as for atx you can always get an old atx motherboard and desolder the connector and just extend it, and mount it to whatever panel you wish. molex I guess could be hooked the same way.
