Development Parallel Port In VB
Discussion in 'Software' started by Stealthrt, 14 Feb 2003.
  1. Stealthrt
    Stealthrt What's a Dremel?
    16 May 2002
    Hey all, i need to find out how to send 8 bit word to the the Parallel Port In Visual Basic. I am controling a relay board with 8 relays on it and i need to be able to turn them on and off. Cant really get anything working so if someone has done this or has examples of it, that would be great to see!
    Thanks for your time,
    David:eyebrow:
  2. TheBigBad
    TheBigBad What's a Dremel?
    4 Aug 2002
    Have you tried dlportio?
    Try googling for it. It includes a example programm with source for both c++ and VB
  3. [DP]Deus
    [DP]Deus What's a Dremel?
    18 Feb 2003
  4. Fowler
    Fowler mmm Cosworth
    20 Nov 2002
    I dunno about u but id recommend trotting down to the local library and getting a VB book out, maybe you could buy one?
    Ud be suprised how much ul learn from em!
    Ive only just started learning VB and im finding the book I have very very useful!
    :D
  5. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    if yer using an nt based os u will need dlportio
  6. djengiz
    djengiz Pointless.
    16 Aug 2002
    Why use the paralel port? Can u use the serial?
  7. eaterofpies
    12 Feb 2002
    yeah sure u can use serial BUT the hardware is about 80 times more complex
  8. djengiz
    djengiz Pointless.
    16 Aug 2002
    Sorry man....... Its just that i have written a component in C++ that is easy to configure and to use from vb
  9. eaterofpies
    12 Feb 2002
    no worries its just for interfacing to the outside world the parallel port is a piece of **** to use because all of the timing is done in the pc where the serial port u need to set data rates etc then u still need to decode the data on the other end (and buffer it)
    might do some work on serial interface at some point when i have money to buy electronics stuff again :(
  10. WildMan
    WildMan Guest
    This matter has been settled. Thanks to all who helped.
    David
  11. x24
    x24 What's a Dremel?
    9 May 2002
    this is my first post in a long long while. :D
    Anyway, try this link: http://uppercanadatechnologies.bizland.com/Customcontrols.html
    It's a VB OCX giving you control over the dreaded parallel port. I've used it and it's so easy, especially with what you want to do. Hope that helps :) BTW, if they charge you for it, sorry. It has been years since I got the OCX, and at the time, it was free.
