Electronics Parralel to serial then back again
Discussion in 'Modding' started by dfhaii, 15 May 2003.
  1. dfhaii
    dfhaii internets
    24 Mar 2002
    i would like to make the data from my parrelel port into a serial stream then back again, is it encoders and decoders which i need to do this and would any1 be able to suggest suitable ics?
    Cheers
    Col
  2. Guest-2808
    Guest-2808 Guest
    The problem here is that there is no standard way of communicating on the parallel port. It's not like data is clocked off in any standard way or anything. Maybe if you just wanted to support certain kinds of printer you might be okay, but basically you are going problems.
    My advice would be to look at either some kind of parallel-in serial-out shift register, or perhaps a microcontroller like a PIC or better still Atmel. You need to sample the data and control lines very fast, and continually transmit their status via the serial line. When I say fast, I mean really fast, like at least one mega-sample per second. Assuming thats 13 bits per sample, you are looking at a 15Mb serial line after including some basic control codes, and that's one way only.
    You can get serial line trancievers, but basically what you need to do is use voltage differentials to determine the signal rather than simple levels, if you want to be resistant to noise over any distance.
    It's a tricky one, but possible.
    Just one more though, another idea would be to make a custom ISA or PCI card with a parallel port on it. You can also get USB parallel ports but they typically tend to be only for parallel printers.
    MoJo
  3. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    it really does depend on what you want to use it for
  4. dfhaii
    dfhaii internets
    24 Mar 2002
    wanna make a wireless lcd, i guessed i wantedit in serial so there is only one dataline to transmit.
    Col
  5. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Not my area of expertese, but couldn't couldn't you use a 8 bit encoded/decoder for your project?
    I think that UARTs are what you want to be looking at ;)
  6. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    Why not just get a serial LCD?
  7. dfhaii
    dfhaii internets
    24 Mar 2002
    do serial lcds only use one data line? could it be done with a parrelel one?
    Cheers
    Col
  8. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    Yes, serial ones are only one data line. The best way I see doing this with a Parallel LCD would be to get a serial backpack for it, thus turning it into a Serial LCD.
  9. dfhaii
    dfhaii internets
    24 Mar 2002
    would it be cheeper to fo that or buy a serial lcd?
    also with a serial does it just use 3 wires +5v ground an data?
    Col
  10. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    It is pretty cheap to do it that way. I love my Matrix Orbital display though.
    You only need those 3 lines for one way serial communication (ie LCD's), 4 for 2 way.
  11. Guest-2808
    Guest-2808 Guest
    Three wires will give you bi-directectional RS232 serial, which is enough for most LCDs. Some draw power from the serial port too, but if you are going wireless I assume you are using batteries or something so that's not an issue.
    You can get wireless RS232 traceivers. Another option would be to use a microcontroller (Atmel, PIC) at either end to convert RS232 to clocked serial, transmit it, and then convert back to RS232. Just take a look around for what RF chips are available and what they can do.
    Actually, I seem to remember that you used to be able to buy a wireless RS232 link for computers. You can certainly get IR ones, I don't know about RF.
    MoJo
  12. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
  13. dfhaii
    dfhaii internets
    24 Mar 2002
    zap i have found a similar chip in the uk, i was wondering what software you used to control your lcd when you were using it? also do they behave ok at 2400 baud as that would make transmitters and recievers a lot cheeper?
    Cheers
    Col
    (ps do u need 2 one at the pc end and one at the lcd end?)
  14. RTT
    RTT #parp
    12 Mar 2001
  15. ZapWizard
    19 Sep 2002
    That chip works at either 2400 or 9600 baud
