Apple Password Protecting a Flash Drive
Discussion in 'Software' started by exavier412, 15 May 2007.
  1. exavier412
    exavier412 What's a Dremel?
    15 Jan 2004
    Hi, I am interested in password protecting my 1GB flash drive. I am wondering how I would go about doing this. Also, I would like it to be able to work with OSX AND Windows. Is this possible? Thanks in advance.
  2. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    On mac : make a password protected .dmg the size of your flashdrive. Make sure its read/write.
    On bouth.. rar/zip ? A bit difficult to use though.
  3. DLoney
    DLoney What's a Dremel?
    21 Feb 2005
    Use TrueCrypt.
    I use it and love it.
    http://www.truecrypt.org/
    :D
    EDIT: Never Mind. I forgot that it doesn't work for Mac- only windows and linux
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    There are specific USB drives that have their own software on them to do it.
    When you plug it in it shows up as a little drive, then you run the program and enter the password and it then mounts the main partition with your data on.
    One of our contractors at work had one with both an osx app and an exe file on the partition. I dont know what brand it was though.
  5. Fod
    Fod what is the cheesecake?
    26 Aug 2004
  6. airchie
    airchie What's a Dremel?
    22 Mar 2005
    I think you're referring to U3. :)
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    Nope. It had nothing to do with portable programs.
    When he plugged it in it showed an emulated usb floppy with two programs on that unlocked/unencripted the main usb storage.
