Case Mod - In Progress Paultan Designs: Titanium R
Discussion in 'Project Logs' started by paultan, 5 Nov 2013.
  1. paultan
    paultan R E V E N T O N
    22 Jan 2010
    This build is to add a new family member to my Titanium Builds.
    I call it the Titanium R. There will be 4 kinds of Titanium that I will be releasing in the near future.
    Titanium X - Extreme build with extreme parts and fully customized.
    Titanium S - Super build with Mid-high end parts using Cosmos 2.
    Titanium R - Radical build using Midrange parts and standard size chasis.
    Titanium J - Jr. size build with M-ATX/ITX parts.
    For this build we will build the TITANIUM R
    With this, I will be using the new chasis from NZXT
    The NZXT Source 530
    This case is very compact but it has some serious space inside.
    what I like about this case is that the metal that were used are very rigid. And it also has very nice details.
    For example,
    the back of the case has some extruded mesh for the fans which gives more space.
    I also like the idea that you could re-adjust where you will be placing your radiator just in case something is hitting your fans/rad
    Other details, for a cheap price, I really like the way they made it fully compatible with water cooling support and the way the motherboard tray was design and created makes this special. :)
    So lets start doing some minor modding to it :)
    as some of you know, I always wanted rotated motherboard tray. With this case its very easy to convert. We just rotate the entire casing! :)
    After removing the front plastic panel.
    I made some tracing to know where I should drill holes on the top panel. :)
    and then drill!
    after a few minutes! Tada! we have converted the case into 90 deg rotated motherboard tray. :)
    Now I will make something for the back to make it look nice :)
    now let us add some more details! :)
    my design inspiration for this build is my favorite chair I saw one time at a store. :)
    so with this, I started doing my concept design using photoshop
    hopefully I can full it off. :)
    Now let's start doing it!
    first is get some cardboard and drawing the pattern needed :)
    then test fit
    now the side panels :)
    now let's do some cutting! Safety first!
    then sanding!
    very smooth!
    also the side panel
    then some bending! :)
    love it!
    done! Stay tuned for the next update! :) Thanks!
  2. Egami
    Egami Why is the dremel on fire?
    27 Aug 2013
    Lovely to see the "low end" cases get some love and attention for a change. Subbed :thumb:
  3. paultan
    22 Jan 2010
    Glad you like it. Thanks!
  4. paultan
    22 Jan 2010
    Finally I was able to find my password and log in. :)
  5. Ianovski
    Ianovski Rawr!
    10 Mar 2011
    Great to see you're picking up this one again! Looking sweet :thumb:
  6. Egami
    27 Aug 2013
    Best intro for an update ever. :D
    Beautiful and skillful work as always! :thumb:
  7. hero1
    hero1 Minimodder
    18 Oct 2013
    Drooling about this one. Subbed!
