Bits PC Audio 101
Discussion in 'Article Discussion' started by Tim S, 12 Sep 2007.
  1. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    heh I just got my new card for audio use. An AWE64 gold ISA (for pure stereo cd sound its vastly supirior to the xfi and for midi it's simply no contest)... sits in a pc who's only job is to play music. Foobar + EAC are the best software for tweeking. I will try asio later but I think my card is not having the output resampled so it probobly won't make a differance.
  2. OmegaRed59
    OmegaRed59 What's a Dremel?
    12 Sep 2007
    I love the site, but I have some problems with the article.
    First of all, in blind tests no one can reliable tell the difference between quality mp3 songs and lossless. I have read a few articles in magazines/online that show this. If you are encoding your mp3s at a good bitrate with a good ripper, etc. you should have audio that will sound great.
    Next is the recommendation of creative speakers?! How are you planning on convincing people to convert to lossless when you recommend these?
    The other thing is when you diss up-mixing. It is very common in recording and in high end audio equipment to upmix. It just seems that this article was thrown together without enough research.
  3. XeroNXS
    XeroNXS What's a Dremel?
    8 Feb 2007
    So do I have to uninstall my old sound drivers and then install the asio one or just install it on top?
    I'm using asio4all and the windows speaker symbol is still visible in my taskbar and i can still adjust my volume with that.
    did i do something wrong?
  4. David_Fitzy
    David_Fitzy I modded a keyboard once....
    8 Jan 2004
    Assuming that the data stays digital. Wouldn't a on board card with digital out to optical receiver work just as well?
  5. completemadness
    completemadness What's a Dremel?
    11 May 2007
    Isn't an improvement subjective ...
    Therefore, if you get a better cable, and you believe it sounds better, the cable has made the speaker sound better (Well more specifically the sound)
    bit of a weird way to word it
    Most people would say "unless your speakers have multiple inputs"
    Theoretically - yes
    However, apparently its not so, and even digital data has its problems, i don't quite understand it myself
    Edit
    Oh, and i would have though it would be nice to tell people how to encode with a high rate VBR to MP3, using EAC, considering mp3 is a much more supported format, i think it would have been nice to explain both ways ...
  6. victorres2
    victorres2 DONT LOOK FOR THE EASY WAY OUT
    4 Aug 2007
    foobar is better than winmedplayer whether through my 1 in. laptop speakers or my headphones, but definetly better when i play it on my house stereo system the bass is more refined and the highs is crystal clear.
  7. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    I'd like to say this is a great guide, if not one of the best bit has come out with (there all good though). I dident realise I could get my music sounding this good, and im still working on it. :thumb: And it's good how the poll on the fourm ties in to an actual artical. :)thumb: thumb again)
  8. Breach
    Breach Modding in Exile
    20 Jun 2005
    Ill have to give lossless a try. Ive been thinking about upgrading my ancient Creative speakers anyway.
    Just thought I would also point out that mp3sparks.com offers FLAC and other lossless formats for download.
  9. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    I'd just like to add, speaker cables Can make a difference; I upgraded my setup from 22awg copper to 12awg silver, and they actually sound better; Everyone who hears them says so, without knowledge that I changed the wiring.
    For Foobar, it's truely a pain in the ass to configure, but well worth it. Fooblog and hydrogen audio have some setups and how to use them; it's against the EULA to share the entire setup.
  10. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    Hrm I've now tried two plugins for winamp, the first stutters and sounds odd (the one on the winamp site) another from elsewhere that was reccommended in the comments started working fine after I installed the asio4all drivers, and I'm inclined to say sounds a little bit better, but that said the winamp volume control has stopped functioning, so to some extent it may also just be louder! :D
    I might give foobar a try later to see if I get on better with that.
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
    You may find a checkbox in the plug-in config to put that right - there is for the Kernel Streaming plug-in.
    edit: nope. I have the same problem with that plugin. Back to Kernel.
  12. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    Ive never heard of FLAC, but monkey's audio is widely popular, and lossless as well.
    I encode my stuff in 192 mp3 or higher though. Just better compatiblity with stuff and its really hard to hear the difference.
  13. Namusetae
    Namusetae Let's go get our Tinfoil hats
    13 Sep 2007
    I'm usually so lazy with forums and stuff like it since seems that every site has one, but hell just had to register to give thumbs up for this article. I'm bit of audiophile (I love quality sound, but I don't have enough ear to notice smallest possible differences) so this article caught my eye instantly. I have been using foobar for a long time but I had no idea about this stuff and all I can say was that this got seriously a 'WOW!' effect out of me when I was done setting everything up. I instantly noticed the difference and actually had to get up and go set my subwoofer volume levels down a bit since it felt like the windows wanted to drop on the floor. I get a noticeably clearer middle and high sounds and quite manly bass.
    Thank you for these great tips, best article I have seen here this far. Maybe I will comment more articles now that I actually registered, time will tell.
  14. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
    I just have to point out one very simple thing. First and foremost, getting decent final output devices (amp/speakers, monitors, headphones) is the single most important thing you can do for your audio. At work, i have crappy onboard sound running through the microscopically thin pass through cables on my keyboard (Enermax Aurora) to a pair of Etymotic Research ER4 earphones and even listening to 192Kbps MP3s I can tell the difference between these and several other expensive headphones.
    After that, just a move up to any discrete audio card will make a marked difference - most noticeable by the lack of interference (no popping and hissing on quiet passages). Then, by using an ASIO driver, you'll probably notice another small improvement. But, it's only at this point that you should even begin to think about moving up to higher bitrate mp3s or FLAC.
  15. xion
    xion Minimodder
    23 Aug 2006
    QFT: :thumb:
    People think nothing of splurging £100ish on a discrete soundcard, and still using aged speaker system. or possibly worse spending another £100ish on a 7.1 UBERBASSBOOST system... do the math people, that £12.50 worth of earbleeding UBERBASS per speaker! :p
  16. maha_x
    maha_x What's a Dremel?
    12 Sep 2007
    The point of this arcticle (one of them) was that even when the digital audio gets loaded from the HDD and sent to your soundcard, it's allready being messed with by windows etc. ASIO bypasses this ensuring you get the sound exactly in it's original form (be it MP3, flac etc.)
  17. zeflash
    zeflash What's a Dremel?
    13 Sep 2007
    I tried the kernel streaming plugin in foobar, it indeed sounded a lot better - crispier on the high freq.
    But I like to have all my library in WMP11 - so I searched a bit and found out that Reclock enables you to override the directsound output with a kernel streaming output - and voilà! kernel streaming in WMP too :)
    Side question: I always wondered about electrical consumption differences between a simple PC speaker system and an actual amp. I know most hifi amps are sucking power whenever they're on, no matter what is output. Is that the same for a PC speaker system? I kinda always leave the sound on when I work on my comp - for sound notifications about emails, IMs, etc.
    But sucking down more watts for silence puts me off. Anyone knows?
  18. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The vast majority of domestic amps are Class A/B with power consumption roughly proportional to the sound level. With no signal the idle current is usually under 50mA. PC speaker/amps are often Class B using even less on idle.
    Only a Class A amp is "sucking (a lot of) power whenever they're on, no matter what its output" and if you don't know, you haven't got one. ;)
    One thing bothering me with all this ASIO crap hype - nobody at the development or pro-user end makes any claim it sounds better. The purpose is so you can do a karaoke act with your PC backing track without so much processing lag on your vocal or instrumental input. It's an alternative driver with low latency to help sound engineers mix tracks, not some "better" method for general listening. The audiophool element are seeing the Emperor's new clothes. :lol:
  19. webchimp
    webchimp What's a Dremel?
    9 Oct 2002
    If you want really good quality sound from a PC, forget the internal soundcard all together, use ASIO and a USB enabled external DAC, some say that uncompressed WAV files, played via USB to a DAC can rival some of the best CD transports. There are now a fair few on the market including those from fairly inexpensive computer brand manufacturers, DIY kits and megabucks "Hi-Fi" brands, here are a few:
    http://www.stereo-link.com/Static/Products-G.html
    http://www.wavelengthaudio.com/usbdac.html
    http://www.perreaux.com/product.php?idp=52
    http://www.hagtech.com/chime.html
    http://www.aqvox.de/products.html
    http://www.belcantodesign.com/prod_eOneDAC3.html
    http://diyparadise.com/shop/index.php?main_page=product_info&cPath=3&products_id=62
  20. RTT
    RTT #parp
    12 Mar 2001
    Couldn't agree more :)
Tags: Add Tags
