Graphics PC freezes on any boot screen
Discussion in 'Tech Support' started by Vayshan, 7 Nov 2011.
  1. Vayshan
    Vayshan What's a Dremel?
    7 Nov 2011
    Hi all,
    I have a problem in that my monitor loses its signal (goes black) or freezes after any boot screen including those from the following sources:
    • Windows 7 HDD installation normal configuration
    • Windows 7 Last known good configuration
    • Safe Mode
    • Safe Mode with Networking
    • Booting from a recovery CD (freezes after the files have been loaded from the disc during the display of the Windows logo)
    • Mini-XP
    • Linux based distro from Hiren's boot CD
    I've tried using both digital and analogue connections to the monitor from the PC in case one switches to the other after the loading screen - (I've had this issue with another PC).
    During POST there are no beeps.
    I've tried detaching the hard disk drive from the motherboard (power and data cable) altogether. I've done the same with the DVD drive to eliminate the thought that the motherboard could not deal with more than 1 SATA interface at a time.
    All fans have been tested and are operating as usual including the HSF.
    Running MemTest returns no errors and so I'm led to investigate further (maybe a graphics card problem) - especially since I have no spare hardware to use.
    Strangely enough, the cause of the problem seems to be after updating an iPad :-S
    If anyone has any ideas or suggestions they would be much appreciated :)
    Thank you all in advance!
    Best regards...
    Setup of the PC in question:
    PSU: Corsair 400W CX PSU
    Motherboard: Gigabyte GA-P31-ES3G iP31
    CPU: Intel Pentium Dual Core E5200
    CPU HSF: Arctic Cooling AC-FRZ-7P Freezer 7 Pro
    RAM: Kingston 2GB Kit (2x1GB) DDR2 800MHz
    Hard Disk Drive: Western Digital WD3200AAKS 320GB SATAII 7200rpm 16MB
    Optical Drive: Sony AD7241S 24x DVD±RW DL & RAM
    Graphics Card: Sapphire HD 3450 512MB DDR2 VGA DVI TV Out PCI-E Graphics Card
  2. Dizzee
    Dizzee What's a Dremel?
    7 Nov 2011
  3. towelie
    towelie How do I Internet!!
    1 Sep 2011
    Vayshan
    Clear a few thing hear you can access the BIOS etc
    But once loading any OS blank including the ones you have tried.
    Silly questions but will ask anyway.
    Have you reseated the card tried /different ports check connections cards FAN etc
    Also does the motherboard have onboard Graphics check that this is diabled or is using your sapphire.
    If all above is still not working maybe worth clearing the CMOS
  4. synpredator
    synpredator What's a Dremel?
    9 Nov 2011
    Have you tried, removing the ram, and stitching the ram inbetween the different slots on your motherboard, I know I had this issue not so long ago.
