Hardware PC Hardware Buyer's Guide November 2010
Discussion in 'Article Discussion' started by Claave, 3 Nov 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. hbeevers
    hbeevers Yes, it can play crysis!
    24 May 2010
    I don't agree at all with swapping out the GTX 460 for a 6850. You can overclock a GTX 460 to be faster than a 6850 for the same amount of money with ease so it would be a better buy for those on a budget. Also how many people use Physx and how many use eyefinity, more use Physx by far. I get it that at stock speeds the 6850 beats the 460 but once overclocking comes into it (and it should on this site!) the 460 comes out on top.
  3. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    How many people, even among enthusiasts, overclock their GPUs. Not very many. How many people, even among enthusiasts, have fallen for the pointless nVidia gimmick of PhysX. Not very many.
  4. eddtox
    eddtox Homo Interneticus
    7 Jan 2006
    I would have loved to see an alternative recommendation for the Gigabyte GA-P55-UD2 as this board is now very difficult to find. I managed to buy the last one from Pixmania which was the only place to have it in stock for less than £95.
  5. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    ^ this.
    In addition, the Corsair CX400 is EOL and nearly impossible to buy new now. Time to review some more budget PSU's (or simply choose a Seasonic S12II-380 for a fiver more).
    Comon bit-tech, keep up. :D
  6. hbeevers
    24 May 2010
    I'd say quite a few do, especially those looking at a budget gaming rig which is where the 6850 came in. My 460's running at 800MHz core and is close to a 470 for frame rates, it cost me £145 that's cheaper than a 6850 and it's faster. As for Physx, if it weren't for physx in mafia 2 then those graphics would be terrible.
  7. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    And thus, in your bickering, you prove Bit-Tech right in swapping out the recommendation. It's been 460, now it's 6850. They State very clearly that THEY value Eyefinity over PhysX, but if you don't you should switch back to the 460.
  8. DbD
    DbD Minimodder
    13 Dec 2007
    Eye infinity and physx are red herrings - a 6850 is not fast enough for eye infinity, and it'll struggle with physx.
    The 6850 is a good card but it's price needs to drop a few pounds, it's not equal to the GTX 460 1G, particularly if you include o/c, which obviously in the "enthusiast overclockers" build should. At the same prices the 460 is simply the better card.
  9. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Interesting that the 6870 doesn't even get a mention. Hmmm.....
    I guess £150 is THE number. That's what I paid for my 66GT all the way back, for Far Cry.
  10. wyx087
    wyx087 Multimodder
    15 Aug 2007
    i don't know about other users. i buy components based on architecture, NOT individual products.
    so, all those Zotac AMP promotion pretty much made your recommendation seem like been bought off.
    im sorry for harsh comment, but only reference design should be recommended for graphics cards.
  11. jodah175
    jodah175 Wannabe Modder
    26 Oct 2006
    Don't be sorry for the harsh comment, cuz they can't even make one of these without copying and pasting bits from the previous one. LAME!!!
    But, I can see you guys have actually taken the initiative to change some things around, and didn't do a blatant copy paste. so props for that. And I would never buy ZOTAC products simply because I prefer XFX's double lifetime warranty.
    And just so you fellas know, MSI doesn't even warranty that mobo for the affordable all rounder. and some of MSI's newer boards make much better choices.
  12. Kamikaze-X
    Kamikaze-X Minimodder
    24 Apr 2009
    wuyanxu....
    huh? so if a product is better than the reference in every single way, including price, you would still buy the reference? unless you are a hardcore watercooler.... i fail to comprehend your logic.
  13. Ph4ZeD
    22 Jul 2009
    Yes but the 470 AMP! is not way better. Its considerably more expensive. The 6870 or 460 GTX (either reference or heavily overclocked) is a far better choice and will leave you with spare cash.
  14. wyx087
    wyx087 Multimodder
    15 Aug 2007
    buying non-reference often means will need to relay on manufacturer to provide overclocking tools as generic tools such as recent Afterburner and older Rivatuner will no longer work.
    it's a draw of luck when buying none reference design. especially when it's cheaper, you don't get something for nothing. cheaper alternative means corner cutting.
    reference design, recommend the card architecture, and let us decide on our own brand of choice is the only unbiased way. not everyone is willing to spend more on custom designs, or less on inferior boards.
  15. Pete J
    Pete J Employed scum
    28 Sep 2009
    Sorry, but I have to disagree strongly on that point. The buyer's guide is all about choosing what are considered to be the best components for the job and if non-reference designs achieve that, so be it.
    Thank God for that! Hyperthreading does bugger all for gaming and its performance benefit in most applications is debatable at best.
  16. rollo
    rollo Modder
    16 May 2008
    wow emo posts lol
    they recommend either 6850 or 460 so no need to go emo.
    470 amp is nearly 480 level of performance from the screens I've seen without the huge heat draw that's associated with the cards so its not a bad purchase
    glad to see the 860 removed it was over the top for what it is.
    id also agree very few will overclock there GPU but a lot will buy pre overclocked versions that have full warranty hence why the amp is ahead of a lot of cards out there.
    £400 for a 480 is borderline crazy with the 6970 due out within a few weeks.
    6870 struggles at its current market price which is nearly £200 for £40 more you can get the 470 amp which is considerably faster talking 10% + you cant overclock the 6870 for any joy or you can and gain nothing.
    it doesnt surprise me that the 6870 has gone awol at its release price of £ 177 it was a bargain at £200 its not a bargain at all
  17. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    Well done on updating the Core i7 950, me thinks you need to relook at the HDD now and change the Samsung F1 1tb to a F4 2tb??
    Yes i know its only 5400 rpm but if u pit it aginst the F1 it is similar in speed and more reliable and twice the size for much the same price.
  18. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Glad you recommended the i7-950 this month.
    Can we get a 460 SLi review too please as it's cheaper than the 480 you recommend and kicks its ass in performance. I know some people will say it's more unreliable than a single card which will make the test results interesting to put this subject to bed. :)
    EDIT: I'd hope that most people reading this site will be overclocking their GPU. The 460 1GB when overclocked keeps up with a 5870 for example which is much more expensive.
    Also I agree it'd be dumb to just recommend reference design GPUs as the custom cooler ones are often the best.
  19. Lehmann
    Lehmann What's a Dremel?
    18 Dec 2009
    the gtx 460 is a great folding card but is no longer watt,cost,ppd leader the 450 is
  20. fata1_666
    fata1_666 ...
    13 May 2010
    Something i don't get your reviews state that if starting a build from scratch your better of going to intel cpus. but just looking at the facts there expensive vs the amd cpus and the motherbaord arent that cheap either.i seriously doubt real world performance with windows 7 as the os anyone could tell what was inside the tower. + why no mention of the sata III wd hard drives currently floating around for £50 offering increased performance???
Tags: Add Tags
