Hello all, Can someone please let me know if the linked momentary switch would be compatible as a pc power button https://www.ebay.com.au/itm/Narva-S...on&brand=NARVA&_trksid=p2047675.c100005.m1851 Thank you
Hello it's a switch which returns at his original position with a spring. So yeah I think it could be easily used for a Pc. It makes contact then goes 'off', just like a classic Pc power button, or as you would do with a screwdriver ^^. Voltage and ampere rating are way above the requirements for a pc switch. totally ok so
I see your point: it might be a switch to open the circuit instead of closing it. BTW I would rather buy on farnell/RS etc to get actual technical drawings But I searched for the reference and got this: https://www.narva.com.au/products/60045BL . So it looks like it's a switch to momentary close the circuit, so to switch on.
I've used momentary switches before on a few projects and they're fine as long as they return to the open position.
