Other PC trouble - Help needed
Discussion in 'Tech Support' started by Cus_de_Sparta65, 20 Mar 2013.
  1. Cus_de_Sparta65
    Cus_de_Sparta65 "There is no dremel"
    24 Apr 2009
    My PC was running fine until I tried that auto O.C. programme that comes with ASUS A.I.suite. I
    set it to 3.6 and then pressed the select button which would normally turn the PC off and on again. this time when it turned off it stayed off and the mobo board lights went off as well although the battery was still connected.
    The CPU i5 3570, MOBO Asus MAX V and RAM are only 2 months or so old with very sparse use. The battery is about 4Yrs old Antec 650W . CPU is water cooled, no leaks.
    Before being turned off the PC was running all the night before and all day the next so rough guess 36 hours which is normal as I usually leave mine on 24/7. It was just web browsing and watching films and downloading some stuff for the most part so nothing too strenuous going on before the problem.
    Any ideas anyone ?
  2. woody_294
    woody_294 Wizard Ninja :P
    31 Dec 2008
    This probably is obvious, but have you tried leaving it unplugged for a while and doing a cmos reset, battery out for a few minutea? Could be a locked transistor or something?
  3. Cus_de_Sparta65
    24 Apr 2009
    I will give that a try , thanks
  4. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Yup reaet the cmos. Some motherboards actually have a button for it, but otherwise pull out the battery from the board and unplug the pc from the wall. Leave it like that for 5-10 and put it back in and try again.
  5. woody_294
    31 Dec 2008
    Hope that works buddy, I know how upsetting a non booting computer can be!
  6. Cus_de_Sparta65
    24 Apr 2009
    No joy with CMOS fix , any other thoughts guys?
  7. woody_294
    31 Dec 2008
    I think you're in to fault finding territory now, one stick of ram, gpu out, unplug all power bar 24 pin and 4/8 pin for cpu and see if it boots is a good start point imo
    Also, check fuses etc
  8. Cus_de_Sparta65
    24 Apr 2009
    Yeah back to basics for me it is then , thanks Woody
