Graphics PC won't boot
Discussion in 'Hardware' started by stepea, 28 Feb 2019.
  1. stepea
    stepea What's a Dremel?
    13 Dec 2009
    This is my spec of my new build
    MSI B450 TOMAHAWK
    AMD Ryzen 5 2600
    2 x Corsair Vengeance LPX 8GB 3000MHz DDR4
    I've used an old PSU enermax liberty 620w and just added MSI 56 Vega. It won't boot - is the graphics card too much for the PSU. I have managed to get to the bios screen using an old ATI 4800 Radeon but with the Vega 56 it won't boot and the red led light is lit on the motherboard.
  2. Vault-Tec
    30 Aug 2015
    That's a very, very old PSU. I know I can be an advocate for not retiring good PSUs too early but man, that one is super old.
  3. stepea
    13 Dec 2009
    Any suggestions of what to replace it with. I've got power to the graphics card MSI logo goes red just no display. Post light red on the motherboard.
  4. Vault-Tec
    30 Aug 2015
    600w if you're not overclocking the Vega, 650 if you are. That seems to be the vibe on OCUK forums.
  5. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Are you using the GPU cables hardwired to the PSU or the modular cable? It's worth trying different combinations of either when connecting the PSU to the 56 Vega.
  6. stepea
    13 Dec 2009
    I think the only hardwired cables are to the motherboard. The rest are modular - red for the graphics card. Black for drives anything else.
  7. Blogins
    3 Aug 2010
    That PSU should have captive cables that you can use on the Vega. Worth giving them a go to see if it'll boot.
    If not then try a combination of one captive 8 pin and another using the modular 8 pin.
