Other PC Won't Shutdown
Discussion in 'Tech Support' started by andrewbarke, 31 Jan 2011.
  1. andrewbarke
    andrewbarke What's a Dremel?
    5 Aug 2010
    being having a problem with my mum pc this last week, every time she shuts it down, it turns off, but after 5-15secs, it powers up again, cant seam to find out the problem!!
    just for ref: its running Windows Vista Home Premium!
    Thanks in advance!!!
  2. bulldogjeff
    2 Mar 2010
    I can only think of 2 possible things. A sticky power switch or a corrupted registry entry in the shut down command.
    When did it start?if you know try restoring to a previous point.
    And check the on/off switch.
  3. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    This is probably a hardware problem. Does it still fail to shutdown if you disconnect the power switch. if so, I'd suspect either the motherboard has gone stupid or there is a short between the 'power-on' pin and ground or the power supply has gone stupid and just turns on regardless of what the motherboard tells it to do.
  4. bulldogjeff
    2 Mar 2010
    I've seen it twice before on vista and once on XP. The restore worked on one occasion and on the other 2 it was a reinstall which fixed it.
    What can some times happen is that is that the power/sleep functions get messed up also check is not set to wake on usb activity like sleep mode.
  5. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Have you tried taking the Power Profile out of High Performance and putting it on energy saver? Could be the reason, though I'm not 100% sure...
    andrewbarke likes this.
  6. memeroot
    memeroot aged and experianced
    31 Oct 2009
    i've seen this also - the computer is restarting not shutting down
    sorry couldnt be bothered looking for the cause
    re install and solved (ok not that great a reply)
  7. andrewbarke
    5 Aug 2010
    thanks for the replys everyone, will try them out tomoz!!
  8. Pha3dr0n
    Pha3dr0n Where's my Valium?
    20 Mar 2003
    Happened to me and took ages to work out - wireless usb mouse was waking the pc upon shutdown. Check BIOS and disable wake on usb.
    Least its worth a shot.
  9. carpetmonster
    carpetmonster What's a Dremel?
    27 Jan 2011
    I had a similar problem, look at all the power on standby settings and options also.
  10. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    wake-on-lan too
