PCI cooling
Discussion in 'Hardware' started by Luda, 30 Jul 2003.
  1. Luda
    Luda What's a Dremel?
    8 Dec 2002
    well its not extreme, or daring, and it doesnt involve water, but it cools pretty well...
    i took 2 fans, zip tide em together and attached em to a pci cover thingy and put it under my graphics card for gfx card cooling goodness :) tell me what u think
    :worried: its not that lame :p
    /edit: errr??? why it not showing pictures?
    /edit /edit : nevermind.. got em workin
  2. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Pics aint working.
    Tripod dont allow external linking.
    So make a link to them or use of the free upload services.
  3. Luda
    8 Dec 2002
  4. sinizterguy
    25 Jul 2002
    Here ya go ... hosted it on my space
    :D
    :thumb:
  5. sinizterguy
    25 Jul 2002
    Copy the address and post the images in your original post and I'll remove them from my post.
  6. Luda
    8 Dec 2002
    thanx alot mate :clap: haha finally working..
  7. sinizterguy
    25 Jul 2002
    Is that 2 zipties holding the two fans together in line ? :eyebrow:
    Is it strong enough to keep them straight?
  8. Luda
    8 Dec 2002
    heh yeh it is, and yeh it does.. i just tightened em real good.. the hard part was puttin the fans onto the PCI slot thing but a lil hot glue did the trick
  9. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    it may of been easier, or not :S if you just drilled a couple of holes to the pci blanking plate and then zip tied the fan to the plate!
    well its an idea!
  10. Luda
    8 Dec 2002
    ya but i dint have the right bits so i improvised :p
  11. ChillingSP
    ChillingSP What's a Dremel?
    11 Jun 2003
    Nice idea :D , a lot of noise i guess though :eyebrow:
  12. Tim S
    Tim S OG
    8 Nov 2001
    I'm interested in the noise levels, as I'm looking for a "quiet" way to get rid of my 50mm fan on my graphics card :)
    Cheers
  13. DeX
    DeX Mube Codder
    22 Jul 2002
    What graphics card do you have bigZ?
