Graphics PCI Express versions
Discussion in 'Hardware' started by drjaydee, 3 Sep 2013.
  1. drjaydee
    drjaydee What's a Dremel?
    1 Sep 2009
    Quick question about PCIe
    I've been looking at buying a GTX460, but I was told there could be some issue as my MB only has PCIe v1 slots.
    I understand there is more than one version, providing more capacity, but all they're all compatible with each other, so there could be some throttling.
    From the wikipedia page, it shows that the capacity for PCIe v1.x is 4GB/s (40GT/s) on a 16-lane slot.
    Looking for specifications on the GTX460, I was again on the wikipedia page for it and didn't know which column was relevant.
    If someone can point me in the right direction, I would be very appreciative.
    Many Thanks
    Nick
  2. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    What motherboard do you have?
    Generally speaking it should work as the PCI-E v2 cards are backwards compatible with the v1 slot.
  4. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    Different PCI-E versions work fine together. They will default to the speed of the older version, in your case PCI-E v1 speeds.
  5. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    Which in real terms what you'll see on the screen will be minimal as the bandwidth likely exceeds the cards bandwidth?
  6. TheMadDutchDude
    23 Aug 2013
    I wouldn't be worried about the motherboard as the performance differences are small between PCIE revisions (with lower end cards as well as higher end).
    The question I'd be asking is: what processor do you have? It may massively bottleneck the GPU, even though it's a mid-range GPU.
  7. Deders
    Deders Modder
    14 Nov 2010
    I have a 670 (more than twice as powerful as a 460) in a PCIe 2x slot, which can provide 20% less than double of what a 1.1 slot can provide and using Riva statistics server I monitor in game how much bandwidth is used. It rarely goes above 50% in my case.
  8. aLtikal
    7 May 2008
    I think the performance hit is tiny. You might lose max 5 fps i think in bad scenarios.
  9. Deders
    Deders Modder
    14 Nov 2010
    It may not be as fast as it might be with higher end cpu's but it would still be a huge improvement.
  10. drjaydee
    1 Sep 2009
    I've got a q6600, would that be a bottleneck? Glad to hear that I won't be taking a huge performance hit from my MB. Thanks a lot
  11. Deders
    Deders Modder
    14 Nov 2010
    the Q6600 although slower than more modern CPU's can still hold it's own if you overclock it.
    If you could tell us which motherboard you have we might be able to tell you how overclockable it is. Generally Q6600's are very overclockable but the motherboard may not be built to withstand higher speeds.
  12. aLtikal
    7 May 2008
    Actually Deders I've read (but cant remember where dammit) that a core 2 quad and DDR2 memory would bottleneck a high end GPU - even if overclocked. Especially with games that are CPU Intensive like BF4 when played online. I should list a source I know, so what I'll say is read up on this first. The example I read included a GTX 670 which was hugely bottlenecked by someone speaking from experience by their old C2Q.
  13. drjaydee
    1 Sep 2009
    I have an ASUS P5QL/EPU motherboard, and the RAM is budget Crucial 667MHz RAM, so nothing special.
    Wouldn't really know how to go about overclocking the CPU, a lot of the guide I can find seem to be tailored towards better MBs and faster RAM.
  14. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    It says in the MB specs that you have a PCIe2.0 slot on the board. Unless the link you posted is wrong.
  15. drjaydee
    1 Sep 2009
    Where are you seeing that? I can't see it on the Specs page.
    Under Expansion slots it says:
    1 x PCIe x16
    2 x PCIe x1
    3 x PCI
    are these not all version 1?
  16. Mechh69
    16 Sep 2009
    Look at the overview tab and it's right under the picture of the MB.
  17. GeorgeStorm
    16 Dec 2008
    It says it has pcie v2.0
    Regardless, even if it was a v1.0 slot it would be fine, and your Q6600 will be fine with the 460, as others have said, you can overclock it for a bit of extra performance if you feel you need it.
  18. drjaydee
    1 Sep 2009
    I am such an idiot! Cheers guys.
    Does anyone know a good source for overclocking guides? Something that explains everything that's going on, because I don't really know the theory behind it.
    Cheers
  19. TheMadDutchDude
    23 Aug 2013
    Agreed with all of the above. A GTX 460 shouldn't be bottlenecked by a Q6600, at all. That motherboard is one which my friend has in his system and you should be able to squeeze 333FSB out of the board and chip. That'll get your CPU running at 3GHz and it should be doable on stock voltage. If not, it may require a slight NB voltage bump as well as a slight CPU voltage bump at best.
  20. GeorgeStorm
    16 Dec 2008
