Modding PCI Slots in Rear Panel.. help :(
Discussion in 'Modding' started by TonyL, 1 Mar 2009.
  1. TonyL
    TonyL modding on welfare
    23 Dec 2008
    Is there a specification or guideline for slot widths and heights for the pci slots (for lack of better wording)???
    I can't see anything in the ATX specification pdf's, and the few sketchup models I've looked at using for templates are different...
  2. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    I *think* that these have been standardized to allow the slots to line up evenly. (if not then you would have to shop for a case to match up with your mobo, etc.)
  3. jrs77
    jrs77 Modder
    17 Feb 2006
    I was looking for specs aswell, but there really aren't any besides the measurment for the I/O-bracket and the motherboards mountingholes.
    However, I've built a backpanel allready myself and know, that it fits perfectly fine.
    I've a Freehand-document available and I'll be adding measurements as I type this, so just hold on for a bit then I'll host an image for you ;)
    EDIT:
    Here you go...
    or as more accurate EPS for direct printout -> http://www.robsinter.net/temp/ATX-backplate.EPS
  4. TonyL
    23 Dec 2008
    hmm, so If i'm using 1.6mm sheet I'd move that fold line.. up? 0.2mm?
  5. jrs77
    jrs77 Modder
    17 Feb 2006
    Every sheet between 1mm and 2mm will work with the measurements as the PCI-brackets are not that 100% precise.
    And if you're using very thin material, which does bend without leaving a rounded edge, then you just cut away that 1mm from the measurements... the 1mm between 125 and 126 ofc.
  6. TonyL
    23 Dec 2008
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    Actually there's no other bends needed.
    You can just bend the part out of a sheet and it's done.
    Another reason I did it this way is, that you can access the screws much more easily, if they're outside the case :cooldude:
  8. stuartwood89
    20 Aug 2008
    That's what I've done for my upcoming scratch build:
  9. jrs77
    jrs77 Modder
    17 Feb 2006
    Can you actually see something in that picture on your screen :confused:
    I've set the brightness on my screen to maximum and I'm not possible to see anything but black there :geek:
  10. stuartwood89
    20 Aug 2008
    I see it just fine. It's probably a bad render from Kerkythea, which for some reason, wanted a black background.
    Here you go:
  11. TonyL
    23 Dec 2008
    Grr, been having a real bad time with sketchup today
    I reckon i've tried to make a rear panel at least 20 times
