Hiya all.. I have been build a system for a friend but i have come across a problem. here are the specs P8H67-M Pro Mobo i5 2500k 8 gig of mushkin ram Palit GTX580 Cosair GS800 PSU CM Storm case PLUS WINDOWS AND OTHER BITS But when i finished building it i have came across a problem. when i plug the graphics card into the top (blue) pcie slot the pc does not reconise it but when i plug it into the bottom(black) pcie slot it reconises it ok?? Is there a problem with the board or am i missing something somewhere?? Look forward to your response Cheers Chris
First problem is you have an i5 2500K in a H67 motherboard, shame on you! As for the GPU problem, have you read the manual and checked in BIOS? It might be the case that various slots can be disabled either that or the card is not seated correctly. Could also be a fault of course!
yeah tried re-seating but no difference..Been scouring through the bios and the manual but i cant see anything wrong???
Probably need to send the MB back, Might be worth asking for a P67 board if you ever have any intention of overclocking.
