Linux PDFLib in FreeBSD
Discussion in 'Software' started by ColD_FusSioN, 13 Jun 2005.
  1. ColD_FusSioN
    ColD_FusSioN What's a Dremel?
    26 May 2004
    Hi... Im trying to install the PDFLib library in a FreeBSD Server, i have previously installed this library in a Fedora 1 Core system without a problem. The library is basically a Loadable Extension Module (DSO) and the procedure for enable the library is the next:
    1.- Identify the PHP Version installed
    2.- Download the adequate DSO depending on the PHP version
    3.- Copy the DSO File (*.so extension) in the extension directory specified with the parameter [extension_dir] in the php.ini file
    4.- Add the line :
    extension=libpdf_php.so
    to the Dynamic Extension section in the php.ini file.
    5.- Restart the HTTP Service.
    For some reason :confused: this only works in Fedora, but not in FreeBSD, does anybody knows any special trick that FreeBSD requires??? Because i'm desperate :wallbash:
  2. ColD_FusSioN
    26 May 2004
    Versions
    I forgot to mention the versions...
    FreeBSD 4.11
    Apache 2.0
    PHP 4.3.11.
    Hope that somebody can help me...
