Hardware Performance Mainstream Graphics Update
Discussion in 'Article Discussion' started by Tim S, 28 Feb 2008.
  1. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    can we have a rolling 'whats better than what' chart
    kinda like http://www23.tomshardware.com/graphics_2007.html?modelx=33&model1=859&model2=722&chart=318 except with /everything/ on it - new ones go on straight away.
    you said in this thread the 9600GT is 'about as fast as a 1950pro'. Now, anyone going out to buy a new card would simply assume the 9600GT would be faster! An x1950Pro only cost 100 pounds about 6 months ago!
    A consistently updated chart of cards listed by performance would be really awesome. The model numbers pretty much mean nothing most of the time.
    well actually i guess they did it already so why bother, but still... we all trust bit more than anyone else, right?! :D
  2. Tim S
    Tim S OG
    8 Nov 2001
    Just to be clear, the 7900 GT is about as fast as an X1950 Pro, not a 9600 GT. The 9600 GT is about 1.7x the performance of both of them.
    I'd like to do a charts, but I don't know whether it's feasible at the moment. :)
  3. nigelleg
    nigelleg What's a Dremel?
    4 Jan 2008
    I feel very happy and content with my 8800gt I got the evga ssc and the more articles i read the more it looks like a pretty good choice
  4. airchie
    airchie What's a Dremel?
    22 Mar 2005
    You doing it with HTPC use in mind? :)
    I hope so.
    I really want to build the best HTPC I can soon.
    Gonna modify the retro TV in my sig with a custom made wooden cabinet and stretch it to allow a 24" widescreen.
    Will need to get creative with car body filler again to make the retro front look natural when wider... :)
  5. Kamakazie!
    Kamakazie! What's a Dremel?
    23 Mar 2007
    I am very itnerested in hearing about the video performance of the 9600GT as i am now intending to put a low power medium spec gfx card in my HTPC to play the odd racing game and audiosurf etc. Game performance is still distantly last in terms of requirements for the card though so the 3850 is currently the leader.
  6. rupbert
    rupbert What's a Dremel?
    28 Jul 2002
    I'm thinking of buying a second XFX 9600GT to run in SLI, how do I go about getting a connector?
  7. Sandwich
    Sandwich What's a Dremel?
    21 Jun 2007
    another thing i noticed about IQ with the two different companies is that ATi's later drivers help the older cards produce better images while nVidia either ignores or hinders the older cards in order to get better frames with later drivers. My 6800GT is producing more frames and lower temps on a lot of my older games (went from 50 something fps in HL2, Doom3, Riddick to the high 70 fps, temps went down too) but the image quality (especially shadows) on all of them has gone to pots where as my 9600XT has had increased frames and better image quality to the point where even at slightly lower settings, it produces more pleasing images than my 6800 rig in a side-by-side comparison. Heck, the images are better than on my 8400 GS on my laptop.
    Call me paranoid, but I think nVidia is purposely doing this to get better numbers because they know that framerates sell cards and not image quality.
  8. Tim S
    Tim S OG
    8 Nov 2001
    There should've been one with your motherboard if it supports SLI. :confused:
  9. rupbert
    28 Jul 2002
    That's what I thought, I didn't receive one with my Asus Commando.
  10. Tim S
    Tim S OG
    8 Nov 2001
    Ah, that board doesn't support SLI - it's a P965 board.
  11. rupbert
    28 Jul 2002
    Indeed, I was confused by another board that I used previously.
    Looks like I'll need to buy a new motherboard along with the second card.
  12. Guest-23315
    Guest-23315 Guest
    Can't you get a BIOS of Xtreme Systems that allows SLi? (I thought there was one)
  13. Tim S
    Tim S OG
    8 Nov 2001
  14. dpdp8888
    dpdp8888 What's a Dremel?
    31 Jan 2007
    Drivers used in tests
    The drivers that the 9600GT used is the latest one, which could give edges to 9600GT in performance.
    Nvidia GeForce 9600 GT 512MB – operating at 650/1,625/1,800MHz using Forceware 174.12 beta
    Nvidia GeForce 8800 GT 512MB – operating at 600/1,500/1,800MHz using Forceware 169.28 beta
    Nvidia GeForce 8800 GS 384MB – operating at 550/1,375/1,600MHz using Forceware 169.32 WHQL
    BFGTech GeForce 8800 GTS 512MB – operating at 675/1,674/1,940MHz using Forceware 169.28 beta
  15. Tim S
    Tim S OG
    8 Nov 2001
    They were the latest available drivers for each particular card at the time of testing.
  16. hawky84
    hawky84 SilentModder
    15 Nov 2007
    Question for the staff : -
    Why do you use Vista 32bit on all the test rigs when it appears on the forums that Vista 64bit is the Vista OS of choice?
  17. Tim S
    Tim S OG
    8 Nov 2001
    For the time being, Vista 32 is more stable when it comes to early drivers and what not... I've tried moving to Vista 64 for testing, but there are a lot of headaches involved with early drivers. We've already transitioned CPU testing, but we're still not comfortable with graphics and motherboards.
Tags: Add Tags
