Hardware Phanteks Enthoo EVOLV ITX Review
Discussion in 'Article Discussion' started by Combatus, 20 May 2015.
  1. Combatus
    16 Feb 2009
  2. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    Why sit a 200mm fan ...or an size of fan(s) behind a solid front panel?
  3. GeorgeK
    18 Sep 2010
    Aren't the little cutouts on each side of the front panel for air intake?
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Correct, though the point I made in the article still stands, I think - If there's only gonna be one fan, make it the exhaust.
  5. GeorgeK
    18 Sep 2010
    Definitely - I was just pointing out that it didn't have a solid front panel. In pretty much every situation I would want at least 2 fans though - 1 intake and 1 exhaust...
  6. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Considering the reduced airflow and the orientation of the GPU I would think a second fan is a must.
    Personally I would go with an AIO which not only would provide an additional fan as an exhaust but would remove the heat from the CPU allowing the GPU full use of any cool air inside.
    For the price, this case would be in my top 3 but I still prefer the top-down nature of the Bit-Fenix Prodigy and Corsair 250D, with the 250D coming top.
  7. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    the matx version of this is simply amazing.
    Could we get a review for that?
  8. Dogbert666
    17 Jan 2010
  9. Otis1337
    28 Nov 2007
  10. coconutboy
    coconutboy Back to the FUBAR
    30 Mar 2010
    Solid review as always from bit-tech. Pretty sweet looking lil' rig.
    From a review/testing standpoint I imagine it'd be somewhat disappointing to see the case produce sub-par results due to the inclusion of the 200m w/o an exhaust, but I think Phanteks made the right call here.
    By including the 200mm with the case, everyone can easily track down a 120mm fan to fill the rear exhaust slot and add even more fans (with or without the rad) to the roof rack if needed. Heck, most people likely have a few spare 120mm fans laying around. 200mm fans by comparison are more of a pain to choose since there are fewer options, and many are low quality. Phanteks frees potential buyers from having to fuss over the 200m decision. Likewise, if an owner is looking to fill the case with 120/140mm fans and remove the 200m intake, it's not a tough decision since they would then likely be purchasing multiple matching fans.
Tags: Add Tags
