News Pheonix jumps into HyperSpace
Discussion in 'Article Discussion' started by Da Dego, 6 Nov 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. craigey1
    craigey1 Minimodder
    13 Jan 2003
    Just wondered what is it that "You'd be able to your hard drive before even getting into Windows".
  3. Firehed
    15 Feb 2004
    I believe that's a typo :p
    Anyways, boot times mean a lot less to me than they used to, alongside raw clock speed and synthetic benchmark results. Perhaps I've lost touch with my enthusiast ways, but I'd rather have something that's stable and reliable than tweaking out every last ounce of performance only to find out that my stability test wasn't quite as comprehensive as I'd thought during the middle of some important work. How often do I reboot, anyways? Once a month, maybe, and I can always find something to do for that minute or so while it's doing its thing. If that doubled boot time means that everything else runs smoother and more reliably in the area where I spend 99.999% of my computing time, fine by me.
  4. RostokMcSpoons
    RostokMcSpoons What's a Dremel?
    9 Dec 2005
    I switched my pc off every night, so boot-times were fairly important to me. Getting into Windows wasn't the major irritation, it was waiting whilst CCC, Anti-Virus, Anti-Spyware and Steam all started up... before then I couldn't access the browser - if that's what I wanted to do, and I was in a hurry, it felt like a long time to wait.
    But last night I discovered the joys of 'Hibernate' mode (oh, and PSShutdown to help make a desktop shortcut for it). Now I can send my pc into a coma almost instantly with Ctrl-Alt-H, but re-awaken it at the touch of the power button - I'm back to a working desktop in 10 seconds (assuming I didn't have many apps active when I sent it to sleep). And the power draw is low enough (allegedly) that I can happily leave it in this mode for days. That job's a good 'un!
    Unless I come across major problems with Hibernate, it rather supplants the need for anything like HyperSpace, good idea though it is.
  5. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    lol, Pheonix.
  6. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    I hate to defend MS but my one Vista machine is also my media center and it comes out of "sleep" (all drives, fans, etc off) almost instantly. The only thing is that it gets very sluggish if I don't reboot at least once a week.
  7. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    To reiterate the article: fast mediaplayer with no fuss.. i love it.
  8. pejcaofrito
    pejcaofrito What's a Dremel?
    19 Jan 2007
    So, Is this related to EFI in any way?
  9. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    One thing that wasn't emphasized is that Windows can boot, whilst using this. So you can check your e-mails while waiting for windows to boot. Brilliant :thumb:
  10. DeX
    DeX Mube Codder
    22 Jul 2002
    Awesome. I was going to ask if HyperSpace had this feature. I'm surprised Bindi didn't mention it.
  11. Guest-16
    Guest-16 Guest
    Hopefully, although Vista still currently doesn't support it.
  12. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    > You'd be able to scan your hard drive before even getting into Windows, and keeping it outside of
    > Windows means that malware can't attack the virus scanner itself (as so many like to do).
    But there's no reliable NTFS write driver for any OS other than Windows.
    > However, those looking to customise it at home will probably be out of luck, as Phoenix plans on
    > keeping the updates to HyperSpace close to home on secure servers rather than have people play
    > around with it.
    Not if it actually is Linux, they can't - large bits of it will be opensource. Not, as always, that this is actually much use to the vast majority.
    Phil
  13. Guest-16
    Guest-16 Guest
    True on the NTFS part - I'd forgotten about that, but it would be a better use of A/V.
    However even if it is Linux and open - getting to it could be an issue if Phoenix only allows updating via a secure server? I'd still like there to be a big development community behind it :blush:
  14. pejcaofrito
    19 Jan 2007
    NTFS3g looks quite good: http://swik.net/ntfs3g
    Ubuntu currently implements it, and IIRC you can even install ubuntu itself over a NTFS partition.
    Cheers!
Tags: Add Tags
