Photo enhancement programs
Discussion in 'Photography, Art & Design' started by Veer, 19 Aug 2006.
  1. Veer
    Veer What's a Dremel?
    3 Dec 2004
    Can you guys link me to some good photo enhancement programs? As there are some photos I would like to touch up. I.e. to remove grain, hue/saturation etc. Different color/setting profiles etc. Thanks
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
  3. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
  4. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    theres a google one now as well isnt there? cant remeber tis name though...
  5. scq
    scq What's a Dremel?
    4 Mar 2005
    Picasa?
    Picasa's really an organization program, with some added touch up features - think of it as iPhoto for Windows.
    The features are really basic, but shoul work fine. Of course, nothing beats the fabled, but costly Photoshop. If you're looking for a free, but still fairl powerful editor, check out GIMP. I haven't used it myself, but a lot of people seem to like it, and it looks like it's well supported with more features than what an average person may need.
    Of course, there are also Adobe's consumer versions of Photoshop. Very, very stripped down copies, with the aim on ease of use more than anything else.
  6. Veer
    3 Dec 2004
    Nope this is not what i meant. Lets make it a bit more simple, what 'third party' program do you use to remove grain in a photograph?
  7. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    noise ninja for the win.
  8. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    I'm going to throw Adobe's Lighroom into the mix, even though it is in beta. and it's free till January.
  9. Veer
    3 Dec 2004
    Is that not only for mac os?
  10. AJB2K3
    12 Dec 2005
    The smooth function? all progams can do it if you lean how.
    FYI gimp is the the same power as photoflop and is on the same level.
    Almost everything photoflop does, gimp does.
    Anything else i havent learnt to do.
    Do your bank balance a favour and download gimp you get photoflop power without the dent in your pocket(unless your a thief)
  11. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    A simple google would have revealed that it's for Mac OS and Windows.
  12. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    It was originally mac only, though.
