Steam Physically moving steam games drive
Discussion in 'Gaming' started by GaryP, 24 Nov 2024.
  1. GaryP
    GaryP RIP Tel
    31 Aug 2009
    I have my steam games on its own physical drive.
    I am moving steam to my new (to me) pc. If I move the physical drives with the games on it, will it stop my new pc downloading all the games again ?
    What folders will I need to copy to the new pc ? Or should I just install steam client and redownload all the games ?
    Current pc is win7 and new one win10
  2. Arboreal
    21 Jan 2011
    From what I remember about Steam storage is you can nominate a particular folder or folders to have your games on.
    When you install the client on your new PC, you should be able to 'tell' it where to look for the folder(s).
    One of my PCs had games over 2 drives and Steam was aware that the files had been downloaded, but they weren't available at that moment when I'd removed the secondary drive temporarily.
    GaryP likes this.
  3. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Thanks I have been having a read up further after posting this and all my games are installed on a phyycial drive, with all the common files so if I put that physical drive in the new pc and point steam to it, I am hoping they will be recognised.
    Mr_Mistoffelees and Arboreal like this.
  4. Arboreal
    21 Jan 2011
    That's what I'd expect to work
    Mr_Mistoffelees and GaryP like this.
  5. Canon
    Canon Reformed
    19 Jul 2010
    If the drive moved to the new PC is mounted as the same drive letter (C:/ D:/ F:/ etc) then when you install Steam on the new (to you) machine Steam should automatically pick up the game installations and place them as installed in your library as before, it may just need to verify game files. If this does not happen, through Steam - settings - storage, you should be able to select your transferred drive as a steam library location, at which point it should then pull all your installed games and you can continue to download straight onto that drive.
    If the drive you are transferring is also your OS drive it might be worth transferring your save game files from documents folder to your new OS drive to make sure they're in the expected location.
    Arboreal and GaryP like this.
  6. GaryP
    GaryP RIP Tel
    31 Aug 2009
    No its not on same drive as OS.. I assumed I would rename as same drive letter. I was just hoping I didn't have to redownload them all. Its only about 1.5TB in total and half of them I wouldn't bother with to be honest.
  7. David
    7 Apr 2009
    All you need is to copy the Steamapps folder, install Steam on the new rig and copy the Steamapps folder to the same place. Done it a dozen times.
    bawjaws, GaryP and Arboreal like this.
  8. GaryP
    GaryP RIP Tel
    31 Aug 2009
    I am literally going to move the whole drive into the new rig, all I have to do is connect it through my steam program ?
    Then what do I copy for my save games... any folders in c drive ?
  9. David
    7 Apr 2009
    No, if your entire Steam install is on that drive, you don't even need to install steam on the new PC. You just install the drive, navigate to the Steam folder on it, create a shortcut of the steam executable and then copy it to your desktop. It'll just work.
  10. GaryP
    GaryP RIP Tel
    31 Aug 2009
    I have files on c drive so I think it was installed on c and then the storage drive was j
  11. GaryP
    GaryP RIP Tel
    31 Aug 2009
    2.3GB steam file on C
  12. David
    7 Apr 2009
    You got anything on there you need to keep? 2.3GB isn't a lot.
  13. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Nothing, I was just saving redownloading everything again. The saved games would be useful though, about 2TB on J drive.
  14. David
    7 Apr 2009
    Job done then. just bin that install, unless it's a much faster drive than the original and has enough capacity.
  15. IamJudd
    IamJudd Multimodder
    30 Oct 2011
    Funny, I thought this thread was about games that physically moved you to tears!
    The Last Guardian and the original The Walking Dead (which is more season 1).
