Graphics PhysX only GPU possable?
Discussion in 'Hardware' started by DarthDVD_AU, 11 Jul 2008.
  1. DarthDVD_AU
    DarthDVD_AU Whats a dremel compaired to a lazer
    13 Dec 2007
    Say you had a NV9600 GPU and you wanted to upgrade to the NV260 or the NV280 and you had a tri-sli mainboard.
    but what if you didnt have to chuck/sell the NV9600 instead you could make that the cuda/physX processer.
    I dont see why it wouldnt work.... it would only be limited by software and it wouldnt take performance away from your main Gpu and CPU.
    I do know that you can disable physX after you had enabled it on your gpu....
    http://downloads.guru3d.com/NV-PhysX-Tweaker-1.0-download-1984.html
    but not sure if you can switch it to a different GPU...
  2. bubsterboo
    bubsterboo New Member
    24 Jan 2006
    Ive got the latest drivers installed with Physx support for my 9800. There is a graphics card selection in the physx settings, i only have one card in my computer so i can't confirm that it works. But its there.
    I don't think you'll have a problem.
  3. DarthDVD_AU
    13 Dec 2007
    but ill be wanting to run it on the 9600 and not my (yet to be purchased) NV260/280
  4. bubsterboo
    24 Jan 2006
    I don't think that will be a problem either. The latest nvidia driver for the GTX 280/260 is compatible with the G92s aswell. That's what i did to get my physx running. Get the GTX 280/260 driver and use a modified inf file so the installer accepts your cards device id.
    I'm pretty sure you can make it work. But i'd wait to hear from a few other guys before putting any money into it.
    Edit: Sorry, G94 i guess it is. Works with that too.
  5. DarthDVD_AU
    13 Dec 2007
  6. Chokwok
    Chokwok New Member
    26 Jun 2008
    Hopefully there will be more games with PhysX support now that ATi/Nvidia are building support in to their hardware and drivers
  7. M4RTIN
    M4RTIN New Member
    11 Sep 2006
    since there are already such things as physx pci cards why would you want to just use a whole gpu for physx
  8. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Because he's already got the card, why waste it and buy a useless PCI card?
  9. DarthDVD_AU
    13 Dec 2007
    Plus i want to upgrade my Main GFX card to something more powerful
  10. bubsterboo
    24 Jan 2006
    Makes more sence then buying a PCI card all round. Then you've got more display ports if you ever need them too.
    Even if you were on the look for a new dedicated physx card, At the price of the PCI card, I'd rather buy a similarly priced Graphics card.
